ADAPTING PT ATTACHMENTS TO SKID STEERS
   / ADAPTING PT ATTACHMENTS TO SKID STEERS #1
STRAWLAWN
The PT 54" Grapple bucket is ideal for my ASV RC-30. I have a universal (Bobcat standard) plate on it but need some assistance in how to modify the PT attachment to fit on the Universal plate. Thank You in advance
   / ADAPTING PT ATTACHMENTS TO SKID STEERS #2
If your universal hitch is male on the tractor, you need a female part to be welded to the implement that you want to use with it. Reverse sexes if applicable.
   / ADAPTING PT ATTACHMENTS TO SKID STEERS #3
Strawlawn: Your inquiry is the first I recall asking about an adapter to go in that direction. There are some threads and posts about adapters to put skid-steer attachments on Power-tracs, but I don't remember the other way.
I would think that if you're only looking at one implement, such as the grapple bucket, I would consider asking Power Trac to sell it to you without the PT mounting plate, and get a welding shop to weld the attachment side of the skid-steer system to the bucket. If you consider a number of attachments, then a Power-trac male mounting plate with locking tabs would have to be welded to a skid-steer implement-side frame.
I hate to steer anyone away from PT, but I think I've seen similar grapple buckets on the web already set up for skid steers.
I have a W.R. Long 4 n 1 bucket. They also make grapple buckets, and will do any width.
Carver's W. R. Long page
W. R. Long, Inc.
P.O. Box 460
1607 Cedar St.
Tarboro, NC 27886
800-823-4570
Fax 252-823-4570
Thank You. I have been working with them recently to have their 60" Grapple bucket cut down to 54". The lowest they can go is 56". Cost is about 2K. The 54" Power Trac grapple bucket attachment is ideal for the RC-30 which is 48" wide. I just need something to go on the PT grapple Bucket that will mate up with the universal quick attach(Bobcat standard) my machine has. 10 GPM/3000PSI Hyd System. Operating weight of the machine is 3,000 Lbs
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2019 KUBOTA SVL75-2 SKID STEER (A52707)
2019 KUBOTA...
2011 FORD F350 SERVICE TRUCK (A52707)
2011 FORD F350...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
CENTRAL MACHINERY 12" PLANER (A57192)
CENTRAL MACHINERY...
