Adapting Model 67 loader for quick-change buckets
   / Adapting Model 67 loader for quick-change buckets #1
jejennings
Has anyone successfully adapted a 1987 JD Model 67 loader to take quick-change buckets? The boom arms look about the same distance apart as later loaders and I[m wondering if anyone sells castings that will bolt up to the boom and cylinders.
   / Adapting Model 67 loader for quick-change buckets #2
The 300x cast brackets may work. See post on converting the model 80 loader. Not sure if it will work on the model 67. The D120 kit is deere p/n BW15939. You will also need new style pins. I upgraded my 430 loader with the current cast holders and links. It was a direct fit, though I made my own pins as deere gets over $50 ea, and i needed 10 of the short pins as well as the long timing pin. I like the grease zerk in the head of the pin. Total for pins alone was $750. Found my holders on eBay for $100 ea, shipped. Looks like hayspears.com can also make a QD frame to fit your loader that accepts current JD 1-4 size implements.
https://r.tapatalk.com/shareLink/to...&share_fid=37868&share_type=t&link_source=app
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2021 Kubota SVL97-2 (A50123)
2021 Kubota...
Sullair 185 (A50123)
6"x8' Treated...
