Adapting a 62C powerflow to a 54C deck.
   / Adapting a 62C powerflow to a 54C deck. #1
DanMc77
JD 4600, JD 2210, JD 332
Has anybody out there put a 62C powerflow blower onto a 54C deck? JD dealer says that they are incompatible.
   / Adapting a 62C powerflow to a 54C deck. #2
I don't know. Do you have a 62C powerflow blower?
If so, hold it next to your deck and see what it looks like.
At the time of my original post, I had a 62C mower deck with a matching powerflow. Now after picking up a 54C deck, I can confirm that the 62C powerflow does indeed fit on the 54C. Perhaps the plastic cover over the belt is different, but the blower with brackets and even the belt work just fine on the 54C.
   / Adapting a 62C powerflow to a 54C deck. #4
Good news, thanks for letting everyone know that information.
Richard
   / Adapting a 62C powerflow to a 54C deck. #5
Do you happen to have a picture of this or more information on how it worked after using it this season?
I have a 2305 with a 54C deck and found a 14 bushel 3-bag PowerFlow system that was setup for a 2305 & 62C deck. I am supposed to go look at it tomorrow and am quite concerned about the blower assembly not fitting right.
Putting the powerflow from the 62C onto the 54C deck was a non-issue. It fit just fine without any modifications and works great.
Edit: Add pics and more description.
I have attached a couple pics of the powerflow installation, coupled with my 20 cu ft wood collection box, built over 20 years ago. There's not much more to say about mounting the powerflow to the 54C. It just went right on, and works. It's actually easier to mount/dismount when I think back to the smaller power flow I had on the 332 with the 48" replacement deck.
This collection box was used regularly on my 318, then on the 332, using the mounting bracket I took off the hydraulic tiller. Now the mounting was adapted to 3 PT with the 2210. I had JD's big collection system on the 318 way back, and hated it because it was miserable to mount/dismount from the tractor. I need attachments that can go on and off the machine in minutes with little effort. I'm not a fan of "baggers" because of the heavy weight of having to lift these bags to dump, especially if working with wet/damp grass clippings. So I chose to build this large capacity box, which has served beyond expectations. It's light, easy to mount, and holds a tremendous amount of stuff, greatly reducing the time spent going back and forth to the compost pile. The only downside to it is that material needs to raked out onto the ground. I've considered designing a new collection box that has an auto-dump feature, but that hasn't happened yet, and this has worked fine for many years.
   / Adapting a 62C powerflow to a 54C deck. #7
Thanks for the pictures! I decided to pick it up and was able to get the 14 bushel MCS for $600. The hardest part about the install was getting the pulley off the spindle.
   / Adapting a 62C powerflow to a 54C deck. #8
Best way, for me, is with an impact tool and getting the right size socket.
Pics of your new setup would be great.
2016 Chevrolet Silverado 2500 HD 4x4 Crew Cab Pickup Truck (A55973)
2016 Chevrolet...
Kubota BX25D (A53317)
Freightliner Tender Truck - Adams Tender (A55315)
Freightliner...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
2016 Volvo VNL Truck, VIN # 4V4NC9TH4GN955551 (A57453)
2016 Volvo VNL...
