Adapt for Hydraulic rear hookups
   / Adapt for Hydraulic rear hookups #1
mikereid
Jackson, GA
Yanmar YM1700
Does anyone know what it would take to add hydraulic rear hookups to a 336D?
   / Adapt for Hydraulic rear hookups #2
Mike, from the Pic it looks like you have a FEL. So, you can go from the output side of it to the rear. That loop could go right back to the original return connection point. There are many other more glamorous ways.
Now, what do you want to do at the rear? Valve? Just have added connections? If the latter, mount a plate or some other way to handle the added lines and quick connects (some just hang out of the way), then have a loop made up to connect the two quick connects to ensure flow when not used.
I can see how that will work. How can I hookup a on off valve for the back that is easy to engage (sorta like a pto)
   / Adapt for Hydraulic rear hookups #5
Normally on tractors of this size the hyd. system is "open center". If that's the case with your tractor, the hyd. valve mentioned will not work. Hyd. fluid constantly flows through an open center system. Blocking that flow no good.
   / Adapt for Hydraulic rear hookups #6
Mike, he is correct. Using this valve in line would starve the pump and kill it. Sorry!
Hose Reel (A53424)
Hose Reel (A53424)
2012 Chevrolet Silverado 2500HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Hydraulic Dovetail Equipment Trailer (A52377)
2019 Fontaine...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
