Actual Weight 3720 Cab???
/ Actual Weight 3720 Cab??? #1
turbo36
Michigan
JD X739 AWS (3), 2016 Toolcat, JD 2038R
Has anyone had their 3720 Cab on a scale to find out the actual weight?
Silver_Knight said:
Do you suspect it to be different than what is on the specs?
Like most published specs, they are subject to change and error.
/ Actual Weight 3720 Cab??? #4
Good Question? I know my bare 3720 Cab is about 3500 lbs.
But with Loaded Larger R4 Tires?
300cx Loader, w/ Heavy Duty Bucket and Reversible Cutting Edge?
Then If I have the filled JD Ballast Box on w/ filled Portland Cement?
Hmm... how much does it way?
I know what the weight box weighs, but what about the loader, and loader bucket, and how much do the rear tires actually weigh in at when loaded?
I think it's a good question...
/ Actual Weight 3720 Cab??? #5
The 300cx loader arms weigh about 1000 pounds from what I remember. That and the bucket are at least 1200+ . I don't remmeber how much the bucket weighs
