Actron OBDII Scanners
   / Actron OBDII Scanners #1
Jarrett
Holden, Louisiana
Kubota L3130DT
Are the higher end Actron OBDII scanners any good? The ones I'm talking about sell for about $179 & $229 at a local AutoZone, not the ones that just read/erase codes. They claim to read live sensor data, not just codes etc. The reason I'm asking is my wife's Taurus is having some issues but it doesn't throw any codes. I think it's related to the EGR, 'cause it seems to be the same symptoms that my F-150 had (carbon buildup in the EGR system). I was wondering if the live data that it shows would actually help diagnose anything. I don't really want to bring the car anywhere to have it checked. I really want to do it myself. I don't mind spending the money on one of those if it'll actually be useful. Plus I can use it to clear the code on my Silverado when the gas cap goes bad, again.....and again.....and again. :rolleyes:
   / Actron OBDII Scanners #2
I can't answer your question about the high end scanners.
However, I bought a scanner from Harbor Freight that sees the codes and will clear them.. about $30 on a sale. Works for me and cheaper than taking it somewhere to clear the codes.
   / Actron OBDII Scanners #3
My high end $7,500 Snap On Modis will. :)
On the Actron it looks like they probably do. This is coppied from their website.
Actron®
"A Scan Tool can be used to read and erase trouble codes, display, record and play back LIVE diagnostic data and perform other tests allowed by the vehicle maker. We have scan tools that cover vehicles 1982 to present depending on required coverage.
A Code Reader can be used to read and erase diagnostic trouble codes as well as other additional features depending on the tool. These tools work on all vehicles 1996 and newer.
A Code Scanner reads diagnostic trouble codes generated by the vehicle's system. Codes are displayed on the vehicle's dashboard and/or identified through audio prompts. These products work with 1981-1995 vehicles."
Then send it on down here to me to use for a little while ;)
   / Actron OBDII Scanners #5
What year is your Taurus and what problems are you having?
   / Actron OBDII Scanners #6
When I did my homework a couple years ago. I came up with this one as being the best bang for the buck.
It will read parameters real time, not just codes. Requires a laptop (prefered) or palm (what I use).
auterra
It's a 2001 with the 3.0 OHV engine, about 80k miles. It shudders pretty hard when you put it in gear and start taking off. It runs a little rough at idle, but it mainly does it when taking off, either reverse or forward. As it's idling, you can kind of smell gas or like it's running rich, but not all the time. While on the throttle it runs smooth. Some of the research I've found on the internet says that the DPFE sensors are known to go bad, and could cause this problem. My wife bought the car from her Dad, and he kept all the records on it. It had the DPFE sensor changed at 36k miles.
I had a '97 F-150 4.6L V8 that did the same thing, except it would actually die out and it threw a code. I don't remember the code off hand, but it was something like "Insufficient EGR Flow". Changed the EGR valve, nothing. It turned out to be carbon buildup in the tube going to the EGR valve. Once I got that cleaned out, cleared the code and it never came back on and the engine ran great.
I know that's 2 completely different engines and different things can give the same symptoms, but I just have a feeling it could be the same thing.
auterra
Hey now, I have an older Palm that I may be able to use...hmmm. Of course, looking at the price of that software and the conector, it'll cost as much as the stand alone scan tool.
   / Actron OBDII Scanners #9
These units all basically do the same thing. Unless you have all of the technical gear and equipment to check and adjust engine RPM's, torque things like that, the higher end units that run off a laptop are overkill.
We own three Audi's, and have used the Equus 3100 Innova Diagnostic Code Reader with Memory Backup for OBDII (Post-1996) Vehicles Amazon.com: Equus 3100 Innova Diagnostic Code Reader with Memory Backup for OBDII (Post-1996) Vehicles: Automotive. I know most of the auto stores have this unit. Costs about $100.
We use it on all our vehicles (and for a few friends too!!!). Whenever the "check engine" light comes on, we hook it up and get the code in less than 30 seconds. Could not be easier.
There are many "ghost" codes that are very difficult and expensive to rack down with certainty. One of the best uses is to check the code, find out what it says in wrong, turn off the code, and let it run for a while to see if it comes back on.
Once you get the codes, you can go to a user forum on the web and get very specific and detailed info on what can or could be done about the problem/issue.
For example, we have a torque sensor possibly bad on one of our Audi's. The repair involves taking out the transmission and would cost about $1,500 possibly more. One mechanic online suggested just unplugging the sensor, noting that it would not affect performance, just lose a few miles per gallon mileage. At least it's an alternative --- one that no dealer is going to suggest.
With various kinds of emission devices, changes in altitude, gas mixture and other factors can set off the "check engine light." Today most dealers want $50 or even $100 just top "read" the codes. Believe it or not, I even heard a local dealer tried to tell someone it was "illegal" for car owners to use code readers. That was the laugh of the year. :p.
This unit we have has worked perfectly for almost four years. We have used it to both analyze problems, and also avoid a couple of very expensive repairs that were advised, but not really necessary, because the codes never came back on in three years after they triggered once.
I cannot give these devices high enough praise. Every vehicle owner today should own one, period.
   / Actron OBDII Scanners #10
I have the Innova 3100 as well. It works real well. I had a line come loose on the evaporative emission system, and it tells which system is at fault. The code there was PO440. I bought mine at Wal Mart. The catch is that there could be several things in that system that you need to check. In my case, even the gas cap could be bad. And, in many sensors, you need a multimeter to isolate the bad componant. The Actron is good for the same tests. I would recommend either one of them.
2022 Club Car...
2021 Kubota RTV-X900 4x4 Utility Cart (A46684)
2021 Kubota...
TOFT 08ER Excavator Ripper (A49251)
TOFT 08ER...
Kobelco 135 Excavator (A47371)
Kobelco 135...
2012 Dodge Ram 1500 Crew Cab Pickup Truck (A46684)
2012 Dodge Ram...
John Deere Corn Head (A49251)
John Deere Corn...
