Action shots of the ag-tec sprayer and 790
   / Action shots of the ag-tec sprayer and 790 #1
spruce Deere
Northmost Idaho
John Deere 790 with loader LS xr3140h also with loader plus a cab
The weather finally cooperated, sprayed for Adelgids, pine weavel, and spider mites. All insects that are determined to ruin the spruce and pine. Not to mention it cuts down on the wasp nests that you find to late pruning different trees:eek: The misses took the pics
   / Action shots of the ag-tec sprayer and 790 #3
Boy, I don't know about that. Drink enough of that stuff, and I can recommend some good cancer chemo drugs, but I can also tell you that they aren't any good for parties.
   / Action shots of the ag-tec sprayer and 790 #4
Boy, I don't know about that. Drink enough of that stuff, and I can recommend some good cancer chemo drugs, but I can also tell you that they aren't any good for parties. I would get a cab!
Thanks mjncad! the tank is 110 gallons. Not really for a small tractor, I just fill to 50 gallons or so. Even then it is a bo-hemith of an implement. As far as drinking the stuff chuckinNH, I dont. A cab would be nice, but there is aways just a slight breeze and you just spray with it, not into it and back in your face:D
   / Action shots of the ag-tec sprayer and 790 #6
I wasn't nagging, but I did lose both an uncle, and a cousin to the shifting winds around here and open station spraying, and I am undergoing chemotherapy myself, so just a heads up if you hadn't thought about it. Nice looking setup for sure!
   / Action shots of the ag-tec sprayer and 790 #7
I have been working with pesticides for 31 years, i started using all the saftey gear 10 years ago, wish i had done it sooner. I wear a mask when i spread & spray, i wear gloves, sunblock,earphones and straw wide brim hats. I also get a lot of exposure protection from the cab.
I did not think u was nagg'n, just concerned for a fello tbn'r! A cab will be part of the next tractor purchase someday....:D
   / Action shots of the ag-tec sprayer and 790 #9
Well then, I will nag. I know how independent my neighbors in Northern Idaho can be, but as lawn king said there are other ways to protect yourself (and your wife) other than a cab. Continue as you are, and you may not be around for "the next tractor purchase someday....." Good luck and Regards, Mike
   / Action shots of the ag-tec sprayer and 790 #10
When I spray, I wear a disposable Tyvek suit with hood, Tyvek boots over my shoes, chemical gloves and a mask in addition to my normal earplugs and safety glasses. The Tyvek stuff is cheap spill protection and since I use blue colorant, I can see where on the ground and on me where the chemicals landed.
After I clean-out the sprayer, the work clothes go in the washer and I head for the shower.
PAIR OF VACUUM PUMPS (A53843)
PAIR OF VACUUM...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53473)
Neckover GL24-2-7K...
12ft Heavy Duty Aluminum Ramps (A53473)
12ft Heavy Duty...
2016 CATERPILLAR 313FL EXCAVATOR (A52705)
2016 CATERPILLAR...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50322)
2020 Exiss Escape...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
