MikePA
Super Moderator
I used square drive stainless steel screws from McFeely's to install my fence. Someone on TBN recommended McFeely's and I concur. Using square drive was substantially better than using Phillips head.
I went with stainless steel screws because of the following information at the McFeely's site;
As most woodworkers are aware, as of January 1, 2004, the pressure treated lumber industry has voluntarily switched from CCA chemical processes to alternative treating methods such as ACQ. While significant testing has been performed on galvanized screws to ensure their compatibility with the new treatment processes, to date stainless steel is the only corrosion resistant material to have gained widespread acceptance for use with these new materials.
I have some other projects planned that will use PT lumber and decided to go with stainless steel nails. Used to be that only projects near salt water had to use stainless steel fasteners. Looks like they're going to be needed regardless of location any time PT lumber is used. /forums/images/graemlins/frown.gif
