Acetylene regulator won't budge
   / Acetylene regulator won't budge #1
Dencotbi
Kingsley, MI
Kubota L3200 HST
Hi. I am trying to remove the regulator from my empty acetylene tank and I can't get it to budge. I've done it before with no problems. I can't remember for sure which way to turn, don't want to damage anything. Any suggestions?
   / Acetylene regulator won't budge #2
To remove acetylene regulator turn it left to right , it's just the opposite of oxygen again to loosen it turn it as if you were tightening a regular bolt.
   / Acetylene regulator won't budge #3
The industry has reverse threads on the regulators to tank so some numb nuts can't by pass the regulator and connect the hoses directly to the tank with common plumbing pipe. The threads are unusual also.
   / Acetylene regulator won't budge #4
All flammable gas tanks have left hand threads to prevent the wrong regulator being used.
So left to right, clockwise? I guess you answered that by saying loosen as if tightening a regular bolt. I'll give it a try. Thanks for the help!
   / Acetylene regulator won't budge #6
Lefty tighty; righty loosey.
10' Unused Feed Bunk (A50515)
10' Unused Feed...
2020 ASV VT70HO Skidloader (RIDE AND DRIVE) (A50774)
2020 ASV VT70HO...
International 1420 Combine (A50514)
International 1420...
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
2009 Ford E-350 Cargo Van (A50323)
2009 Ford E-350...
