Accessories power issues
   / Accessories power issues #1
Newtothegrounds
Mahindra Emax 25L HST Cab
Mahindra emax 25L HST Cab
I have some intermittent power issues with my cab accessories (front wiper, washer fluid, work lights on front, work lights on rear, blower for cab heat (just the blower)). The issue doesn't seem to effect the lights build into the hood of the tractor, the 4 way lights or braking lights, so seems to be specific to the cab. Sometimes the stuff works some times it doesn't. If it's working usually I'll be around 2000 rpm or lower and if it's working it does for a bit and if I go above 2k rpm might randomly kick out than may or may not come back on 30min later. Sometimes stuff works for 30 seconds than dead for an hour other times works for 5min than on and off on and off. Just trying to wrap my head around where to start not sure if it's an alternator issue, or bad wire somewhere some type of voltage regulator. Any help or insight is much appreciated thanks.
   / Accessories power issues #2
Sounds like a grounding issue. Make sure you have a good ground to the cab.
2015 Ford Taurus SE Sedan (A44572)
2015 Ford Taurus...
1999 Mack RD688S Truck, VIN # 1M2P267C4XM041712 (A44391)
1999 Mack RD688S...
1999 Mack RD688S Truck, VIN # 1M2P267Y6XM045353 (A44391)
1999 Mack RD688S...
2014 Ford Taurus AWD Sedan (A44572)
2014 Ford Taurus...
2017 Ford F-550 Reading Service Truck (A44571)
2017 Ford F-550...
2011 Ford Ranger 4x4 Pickup Truck, VIN # 1FTLR4FE6BPA87071 (A44391)
2011 Ford Ranger...
