Accessing Kubota with Front End Loader for Maintenance
   / Accessing Kubota with Front End Loader for Maintenance #21
   / Accessing Kubota with Front End Loader for Maintenance #22
After releasing the lever on the side panels pull out on the bottom of the panel and lift.
   / Accessing Kubota with Front End Loader for Maintenance #23
Release side lever, pull bottom of cover out toward tire about 3 inches and then lift straight up. I have a 3710 and work on it with the loader in the down position. Make sure to lube the release lever while you have the covers off. The lever is easy to break off if they haven't been lubed for a long time. Replacing the oil filter is a pain and i normally remove the bottom cover (gray) panel left bolt. Gives just enough room to get the filter out without to much trouble.
Thanks. I will yank harder on it and get it off.
2022 Club Car...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
Auger (A50860)
Auger (A50860)
2009 Mazda 5 Van (A48082)
2009 Mazda 5 Van...
Hotpoint DBL1550BALAD Dryer (A50860)
Hotpoint...
2014 Ford F-150 XL Ext. Cab Pickup Truck (A50323)
2014 Ford F-150 XL...
