AC WD hydraulic problem
   / AC WD hydraulic problem #1
shop hermit
ks.
AC WD
I have a wd with a hydraulic problem. Sometimes...usually upon first starting up...the hydraulics work normally the first time used. Then they work very slowly, but at normal pressure. Takes at least 30 seconds to raise the loader bucket to full height. Once in a while during subsequent operation it will lift at normal speed for one cycle, then resume the slow-lift thing. All the adjustments are correct as far as I can tell. There is some leakage of transmission oil into the hydraulics and it is a little too thick, but would this cause the intermittent operation. It acts as though only piston in the pump were working. Put some Rislone in but it didn,t help.
   / AC WD hydraulic problem #3
AC never did have a working hyd. system!!----I have 3 wd's and 2 wd-45's and the hyd. does NOT work on any of them!----The best fix is to mount a real hyd pump (either live or pto drive) and junk the ac system! ----I did this for a buddy of mine and now he uses his 45 all the time!! thanks; sonny580
(INOP) FORD 8N / 9N TRACTOR (A51247)
(INOP) FORD 8N /...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
2016 Ford F-450 Crew Cab Knapheide Service Truck (A52377)
2016 Ford F-450...
2016 JOHN DEERE R4038 LOT NUMBER 180 (A53084)
2016 JOHN DEERE...
JOHN DEERE 437E KNUCKLE BOOM LOADER (A51246)
JOHN DEERE 437E...
2020 COLOMBO TM LOT NUMBER 199 (A53084)
2020 COLOMBO TM...
