AC to DC converter
   / AC to DC converter #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
We have a (edited to correct) elliptical (NOT treadmill) that I want to start using.. My wife has relocated (ie lost) the power cord to it while cleaning up.. (rant on) After the cord being in the room for 3 years it mysteriously disappears and she 'hasnt seen it and hasnt moved it' - but she had to move it because its not there anymore.. (rant off)
The machine has a decal that says "9v - 1.5 amps" - and take the typical looking power plug connection..
Assuming I can find a plug that fits the pin, do i have to use a converter with that exact output? OR can you use something higher/lower?
thanks
Brian
   / AC to DC converter #2
Radio Shack used to sell a multipower pack that would let you change the voltage and had multiple tips to fit a variety of plug ins. Our local Goodwill also keeps a tub full of various power supplies. Shouldn't be that hard to find another one.
After i posted the question I remembered we have a universal adapter (range from 3 to 9v at 1300mA). And I it had a pin that fits the machine..
My problem is now that the polarity (is the center pin + or - )on the machine is not marked and the owners manual does not indicate it.. I have emailed the company and asked..
Is there a 'standard' polarity for US electronics? It appears the the center pin is + on most adapters I have looked at - but didnt want to make an assumption..
the machines say 1.5 amps and the adapter is 1300 mA (which i think converts to 1.3 amps) - will that 0.2 amps make a difference?
Brian
   / AC to DC converter #4
Center positive is standard. I would try that first if there isnt a label saying which should be used (the label should look like the one below if it is center positive).
Aaron Z
   / AC to DC converter #5
1.5 amps is what you can expect the machine to draw, I would get a power supply that is rated at least 2 amps, that gives you a little wiggle room. In case you find a converter that is rated in watts, Watts / volts = amps. you need something greater than 14 watts. 14 watts / 9 volts = 1.555 amps. If you underpower your supply, things get HOT, or your motor burns out.
   / AC to DC converter #6
Something is not correct here or we don't have the full story.
No treadmill is going to operate on 1.5A @ 9V ~14W. Any treadmill of any kind intended for an adult will have at a min a 1HP motor and system is going to take close to 900W to run including controls, etc. Better treadmills have motors close to 1.5 -2 HP.
9v/1.5A may run some aux attachment.
sorry.. I made a mistake - It is an elliptical not a treadmill - dont know what I was thinking when i typed that..
it does have a display and there is some sort of resistance to it..
The 9v/1.5A is what is label near the connection point..
sorry
brian
Aaron Z
That is what I though/noticed on other converters..
The funny thing was I did a google search and found a 9v/2A converter with the pin size i need and it was the opposite - center pin was negative..
Still havent heard back from the mfg yet.. I may just buy their converter (assuming it is reasonably prices) and not worry about it..
thanks
brian
   / AC to DC converter #9
You can find replacment connectors at radioshack. Don't plug in the new converter till you get the polarity correct, Diodes can be defeated(smoked) and toast the whole unit.
   / AC to DC converter #10
Brian
Just a guess, but the 1300mA (1.3A) is probably what it can supply at 9V. No wattage rating on the case?
9V X 1.3A = 11.7 Watts
3V X 1.3A = 3.9 Watts
Dave.
More info coming soon! (A53421)
More info coming...
2019 Freightliner M2 106 8.5 CuYd Street Sweeper Truck (A53422)
2019 Freightliner...
COATS 30-30 AIR FLATE TIRE CHANGER (A54756)
COATS 30-30 AIR...
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
(49) 2" X 2" X 71" TUBING (A54756)
(49) 2" X 2" X 71"...
2013 JOHN DEERE 470G LC EXCAVATOR (A52705)
2013 JOHN DEERE...
