AC to DC converter
   / AC to DC converter #1
thatguy
Elite Member
Bedford, VA
John Deere 2320
We have a (edited to correct) elliptical (NOT treadmill) that I want to start using.. My wife has relocated (ie lost) the power cord to it while cleaning up.. (rant on) After the cord being in the room for 3 years it mysteriously disappears and she 'hasnt seen it and hasnt moved it' - but she had to move it because its not there anymore.. (rant off)
The machine has a decal that says "9v - 1.5 amps" - and take the typical looking power plug connection..
Assuming I can find a plug that fits the pin, do i have to use a converter with that exact output? OR can you use something higher/lower?
thanks
Brian
   / AC to DC converter #2
Radio Shack used to sell a multipower pack that would let you change the voltage and had multiple tips to fit a variety of plug ins. Our local Goodwill also keeps a tub full of various power supplies. Shouldn't be that hard to find another one.
After i posted the question I remembered we have a universal adapter (range from 3 to 9v at 1300mA). And I it had a pin that fits the machine..
My problem is now that the polarity (is the center pin + or - )on the machine is not marked and the owners manual does not indicate it.. I have emailed the company and asked..
Is there a 'standard' polarity for US electronics? It appears the the center pin is + on most adapters I have looked at - but didnt want to make an assumption..
the machines say 1.5 amps and the adapter is 1300 mA (which i think converts to 1.3 amps) - will that 0.2 amps make a difference?
Brian
   / AC to DC converter #4
Center positive is standard. I would try that first if there isnt a label saying which should be used (the label should look like the one below if it is center positive).
Aaron Z
   / AC to DC converter #5
1.5 amps is what you can expect the machine to draw, I would get a power supply that is rated at least 2 amps, that gives you a little wiggle room. In case you find a converter that is rated in watts, Watts / volts = amps. you need something greater than 14 watts. 14 watts / 9 volts = 1.555 amps. If you underpower your supply, things get HOT, or your motor burns out.
   / AC to DC converter #6
Something is not correct here or we don't have the full story.
No treadmill is going to operate on 1.5A @ 9V ~14W. Any treadmill of any kind intended for an adult will have at a min a 1HP motor and system is going to take close to 900W to run including controls, etc. Better treadmills have motors close to 1.5 -2 HP.
9v/1.5A may run some aux attachment.
sorry.. I made a mistake - It is an elliptical not a treadmill - dont know what I was thinking when i typed that..
it does have a display and there is some sort of resistance to it..
The 9v/1.5A is what is label near the connection point..
sorry
brian
Aaron Z
That is what I though/noticed on other converters..
The funny thing was I did a google search and found a 9v/2A converter with the pin size i need and it was the opposite - center pin was negative..
Still havent heard back from the mfg yet.. I may just buy their converter (assuming it is reasonably prices) and not worry about it..
thanks
brian
   / AC to DC converter #9
You can find replacment connectors at radioshack. Don't plug in the new converter till you get the polarity correct, Diodes can be defeated(smoked) and toast the whole unit.
   / AC to DC converter #10
Brian
Just a guess, but the 1300mA (1.3A) is probably what it can supply at 9V. No wattage rating on the case?
9V X 1.3A = 11.7 Watts
3V X 1.3A = 3.9 Watts
Dave.
John Deere skidsteer (A55788)
John Deere...
30008 (A55758)
30008 (A55758)
UNUSED LANDHONOR UNIVERSAL ADAPTER PLATES (A54757)
UNUSED LANDHONOR...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2018 CATERPILLAR 903D WHEEL LOADER (A52705)
2018 CATERPILLAR...
