AC power from BX
   / AC power from BX #1
Anonymous Poster
Epic Contributor
I noticed that one of the new JD models has a neat feature- an AC outlet for running drill, hedge trimmers, etc when in a remote location.
Does anyone have advise on how to do this on a BX? Can you get a cigarette lighter for the BX? and then use a simple inverter? Or is there other inventive, more permanent, safe, astheitic, ways to do it.
Just looking for another project.
Jim
   / AC power from BX #2
Jim
<font color=blue>is there other inventive, more permanent, safe, astheitic, ways to do it.</font color=blue>
The only one I can think of that meets most of your requirements is to quit smoking.
Al
   / AC power from BX #3
Yep. Any RV store, most auto parts places, even Wal-Mart has inverters. Hook to the battery and you have AC.
Remember the wattage and keep the tractor running to keep the battery charging.
To little power causes more damage to appliances/tools than nearly anything else.
   / AC power from BX #4
Jim just use a cheap inverter that will wire directly to your battery or use a cigarette lighter version. radio shack or any autoparts store can supply a lighter/pwr receptacle.
   / AC power from BX #5
Seems if you do a search on "work lights" or "cigarette lighter" youll find all kinds of good threads on this and similar subjects. Really seems to beg the question what you want that power for. Cordless drills and gas trimmers and the like certainly spring to mind fast. Im sure that it would be cheaper and easier than playing with the wiring on the tractor too.
   / AC power from BX #6
Cordless drills are quite good these days. But gas trimmers are pretty heavy 10 pounds or more. Cordless trimmers are kind of weak and don't last too long.
I wonder how big an inverter (in watts) you can safely run off the BX. In other words how much spare capacity in the alternator.
Short of getting a PTO generator, it would be nice to have a couple hundred watts off the alternator.
   / AC power from BX #7
Remember, the battery capacity also comes into play. Good inverters are not inexpensive.
Egon
   / AC power from BX #8
you shouldn't have a problem with an inverter plugged into a power outlet, I mounted one for my sprayer, if you look closely to the right of the tool box, it's weather proof although i don't leave it outside.
   / AC power from BX #9
you shouldn't have a problem with an inverter plugged into a power outlet, I mounted one for my sprayer, if you look closely to the right of the tool box, it's weather proof although i don't leave it outside. there is an unused wire end under the seat that is hot only when the switch is on, you can tap into that.
   / AC power from BX #10
Milkman,
Please put a 10 to 15 amp fuse or circuit breaker between your batttery and 12v outlet if you haven't already done so. I have seen both ruined equipment and batteries from using unfused outlets when getting a short. If you are pulling more than 10 amps off a cigarette plug type adapter you really should think about moving up to a beefier direct hookup.
My .02 cents,
mark
mark
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2020 MDB UT125KPLUS FLAIL MOWER (A51247)
2020 MDB...
2025 SDLANCH IRGC40 UNUSED Electric Tricycle (A53117)
2025 SDLANCH...
2025 K1220 UNUSED Single Garage Metal Shed (A53117)
2025 K1220 UNUSED...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
