Ac compressor repair.
   / Ac compressor repair. #1
Dwilson540
Kubota L4200
I’m going to replace the compressor on my Kubota L4200. I just learned that I can borrow the gauges at O’Reilly. Looks like I just bleed off the Freon to reduce the pressure in the lines. Then reduce the tension on the belt. Remove and replace the compressor. Recharge with Freon. I’m guessing the compressor will have information as to the psi required. Any information that will make this less complicated would be appreciated. Thanks.
   / Ac compressor repair. #2
Once you open the system you really should run a vacuum to remove any moisture and check for leaks.
After a compressor replacement I would add some compressor oil back into the system, how much depends on if the compressor is oiled before installation or used, etc.
Normally refrigerant is added by weight not pressure. Your compressor will generate the pressure on the high side and the low side pressure should be enough to ensure the system is full and that the expansion valve is working properly.
Details vary between systems.
Not a hard job and all the tools will cost less than paying a shop, any future uses is a bonus.
   / Ac compressor repair. #3
There's more to servicing A/C systems than the "nuts and bolts" then adding freon. Why does the compressor need to be replaced?
   / Ac compressor repair. #4
There are specific details for the required vacuum to be pulled and for how long it has to be held. If you don't do it correctly there will be moisture in the system which will probably mess up the small port on your expansion valve. Do not skip this step.
   / Ac compressor repair. #5
o_O
That would be a $10,000 fine.
As @Harry in Ky states, why are you replacing the compressor? You could be ruining that one too. If something came apart and the system is contaminated, you'll just waste the new compressor.
   / Ac compressor repair. #6
Your post makes it sound like you haven't had any exposure to this sort of work. If you don't have a WSM and good mechanical aptitude, get someone else to do it or coach you in person.
   / Ac compressor repair. #7
What type of failure did the OEM compressor have? You'll want to inspect the inlet screen/filter/dryer for debris. And you should replace the valves in the service ports.
If the failed compressor sent metallic bits through the system, the replacement compressor will fail in short order also if you didn't flush the system or replace the evaporator and condensor. Debris in the system is a whole nother animal..
Replacement a/c compressors are also a big issue today. Many can be junk right out of the box. It's best to stay OEM if you can swing it.
   / Ac compressor repair. #8
They used to use dryer filters in automobile air conditioners. And anytime we did a compressor change we change it. For protection of the new one an assured of no moisture in the system. It is the thing under the sightglass
2013 Ram 4500 Versalift Bucket Truck (A50323)
2013 Ram 4500...
KJ (9) 5'x5'6" Wire Mesh (A50121)
KJ (9) 5'x5'6"...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52748)
Marliss Industries...
2013 Ford F-150 Ext. Cab Pickup Truck (A50323)
2013 Ford F-150...
2014 JLG G12-55A 12,000LB 4x4 Rough Terrain Telehandler (A50322)
2014 JLG G12-55A...
