AC Clamp Meter
   / AC Clamp Meter #1
Mrwurm
Veteran Member
South East Michigan
New Holland TC30 Hydro 4x4, Gravely Zero Turn Mower
I'm getting tired of my old analog multi-tester. I've had it for 25 years and I think I'm due for one of those fancy digital ones. The meters with the clamp to measure current have really caught my eye.
/forums/images/graemlins/smile.gif
Home depot has Greenline models for $60, $70, $80, even a bit higher. They all look about the same to me. They also have GB models for $60 to $80. Anyone have any tips about these items?
/forums/images/graemlins/wink.gif
I use my meter to measure resistance, check continuity, measure AC voltage, and measure DV voltage.
/forums/images/graemlins/cool.gif
Also, will the AC clamp allow me to measure amp draw on the line that runs from my new generator to the main panel? It would be nice to know exactly how much power I was using. Adding up watts and estimating surge watts is not very accurate.
/forums/images/graemlins/laugh.gif
   / AC Clamp Meter #2
I don't have experience with those but I have used Fluke multi meters for my work and they are one of the best around. Check out the fluke clamp meters at www.contacteast.com. I have no affiliation with either Fluke or Contact East.
Dog
   / AC Clamp Meter #3
Most of my servicement like th Fluke Brand. They have found them to be the most durable but I think you will they are the most expensive. My guys also buy them because of the abuse they give them. If you take care of most of them they will last a long time.
murph
   / AC Clamp Meter #4
If I were to buy a multimeter at home depot it would have to be greenlee, otherwise, mine are either fluke or aw sperry.
I have to second the opinions earlier about Fluke. I have one that has withstood a fall from my pickup at about 20 mph....still works
David
   / AC Clamp Meter #5
I like the Fluke brand also, but one of the biggest complaints I have heard (and experienced) is that the display sometimes have digits that start to fade due to the way the LCD panel is connected through a 'conductor strip' to the PC board of the meter. I've had to fix a couple of these with this type of problem, but they are still good meters. Yes, the clamp-on type will let you measure amperage through a line, some models will also do both AC & DC current in a clamp-on version, but the dual-mode versions usually run a little higher. If you want a good meter, I would mail-order one, but a Fluke brand will problably be a lot higher that those prices you mentioned. I think the 87 series runs at least over $235 nowadays, it is a true RMS version. A clamp is sold as an accessory.
J.W.
   / AC Clamp Meter #6
Fluke clamp on meters have a major DEFECT built right in to them. When you aren't watching, those clamps spread apart and turn into little legs, and the whole dang meter walks away.
GB ain't a bad meter, but, why spend that kind of money for something when there are tons of Sperrys going across Ebay for under $25-.
I don't get near as upset about a $25- meter walkin off as I do about an $*)- meter walkin off.
The common disadvantage to all digital meters is they loose a lot of accuracy when they are around RF. Other than that, they sure are nice when you need reading glasses to see an analog needle.
   / AC Clamp Meter
Thanks to all that replied.
Will the clamp measure ac amps on a cord that has two hots and a neutral? (my 240V cord from my generator to transfer switch) I have heard that you have to separate the the individual leads and only have the clamp around one hot at a time. This does not sound practical. I hope this is incorrect.
Also, what is 'true rms' all about?
   / AC Clamp Meter #8
That is correct. If you put the clamp around all the leads at the same time the magnetic fields cancel each other out and the meter will read zero. Incidentally that is how a ground fault detector works.
   / AC Clamp Meter #9
Since AC is a constantly varying voltage and current going from some peak positive to some peak negative, it is not normally stated in terms of it's maximum peak to peak. RMS is a way of determining the effective result of that variation relative to a DC type voltage. Here is <font color="blue"> a basic description </font> of rms.
   / AC Clamp Meter #10
I agree with the other guys about the Fluke meters. They're one of the most popular with professionals, but I have an Extech digital clamp meter, with temperature probe, that I've had for 13 years (since 4/21/90 in fact) and no complaints yet. You can see a few of their meters at this site. Of course, I paid $180 for it 13 years ago.
2014 Ford C-Max Energi Hybrid Hatchback (A48082)
2014 Ford C-Max...
Adams 5 ton Fertilizer Buggy / Wagon (A51039)
Adams 5 ton...
2008 Saturn Astra XE Hatchback (A48082)
2008 Saturn Astra...
2015 Jeep Cherokee SUV (A48082)
2015 Jeep Cherokee...
2013 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2013 Ford F-150...
2011 BMW 128i Convertible (A48082)
2011 BMW 128i...
