AC Clamp Meter
   / AC Clamp Meter #11
I have to go with Fluke all the way. I use them everyday at work and have found the Fluke to be the most reliable. As for the displays. On some of there models you can put in a different display that is much brighter than the stock model.
   / AC Clamp Meter #12
I was not refering that the 'display' itself is the problem, but the method of which is used to 'connect' the display to the contacts of the PC board of the meter itself. This 'connector' is a small strip that is actually a 'sandwich' of conducting material and non-conducting material, kind of spongy in nature (flexible). Eventually it tends to loose continuity with the display, causing some of the digits of the display to appear dim or completely shut off. Sometimes pressing on the outer casing of the meter causes the digits to re-appear, but since I don't have three hands while taking a measurement, it gets a little irritating.
J.W.
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
New/Unused CFG Industrial QK18R Mini Excavator (A57453)
New/Unused CFG...
6' SCRAPE BLADE (A52708)
6' SCRAPE BLADE...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
1993 Ford F-250 (A56858)
1993 Ford F-250...
Kubota R5205 (A57148)
