AC 180 leaky injector
/ AC 180 leaky injector #1
Birdhunter1
Murphysboro, IL
Mahindra 2638
I have an Allis Chalmers 180 deisel that is leaking between the head and injector, below the rubber seal. Do they make a seal kit for the inector or do I need to replace the entire thing? I know I'll find out when I call the AGCO dealer tomorrow just wanting to know if anybody has done this repair before, doesn't look too difficult and I have replaced injectors before, but never dealt with trying to find a seal kit.
Among other things I have fuel issues with it, started running a biodeisel blend in it and it hasn't ran much this year so it has gunked up the tank something bad. Last week I though it was out of fuel as after I cleaned out the sediment bowl it woudl fill back up. Lookes in the tank and had about 15 gallon in it, the sediment bowl body was caked full of gunk and would allow fuel to pass, cleaned it out, replaced the fuel filter (whole reason of starting this project) and after running a few hours the bowl had about 1/2" of sludge in it and the screen in the top of the bowl was about 90% blocked. It will run about 20 minutes and it dies, it actually sucks the fuel out of the lines and filter and the screen won't allow enough fuel to pass through to keep it running. Makes it kinda hard to cut hay!
Oh the joys!
/ AC 180 leaky injector #2
That's one of the major downfalls of biodiesel is it's relatively short shelf life. It is not a stable fuel so if your equipment is going to set for any length of time I would recommend you add a fuel stabilizer additive. If the fuel's that bad you may need to drain and clean your fuel tank. Also add some diesel fuel biocide to kill off the blossoming bacteria colony you have growing in there. Between ULSD and biodiesel many have also had a increasing problem with fuel leaks due to rubber seal deterioration. Like you said, Oh the joys!
John Deere Forks (A64126)
John Deere Forks...
1995 Freightliner FLD120 Tandem Dump (A62613)
1995 Freightliner...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
213137 (A64276)
213137 (A64276)
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
