AC 170 quits running...
/ AC 170 quits running... #1
ATP
Bronze Member
Land Between the Lakes
John Deere 3038e and LS K 5047
Runs fine for a while then I hear the engine rev up just a bit...then its like I turn off the fuel...(which is whats wrong I think)... something is causing the fuel to not flow....
I just inherited this tractor,,, changed all the filters...
I checked the bowl under the tank,,, full
and glass bowl below the fuel filter,....full...
usually when u let it set at 30min or longer... you can crank it a few times and it will fire back up.. whats causing this... any ideas???
thanks
/ AC 170 quits running... #2
If it has the rubber plunger for priming the fuel system check that out. I have an AC200 that was doing the same thing & the tip of the plunger was loose letting it suck in air. I could see small bubbles in the glass fuel filter when it was running.
/ AC 170 quits running... #3
IT would be helpful if you told us wether it was gas or diesel
Diesel... sorry LD1...thanks for the plunger tip... ill check that and look for bubbles.
/ AC 170 quits running... #5
Are you sure you got all the air out of the lines when you changed filters??
No, how would I be sure...?
I did run for 30- 45 min before this happened.
and it has happened before I changed the filter
/ AC 170 quits running... #7
I am not that familiar with the diesel version but the engine should have a purge screw located close to the injection lines...
You should be able to open it up a bit to purge the air out of the lines...
I ran my 1720 New Holland out of diesel 1 time and it was easy to get her back up and running using the purge screw...
I'll look for a bleed screw... thanks....
U know.... I got to thinking after this happened and thought back to the changing of the fuel filter... there was a layer of "sludge" in the sediment bowl....
I am wondering if a thorough cleaning of the fuel tank may be in order...?
if so... what would it take to accomplish this...?
/ AC 170 quits running... #9
Did you ever find out what was wrong?
HONDA Plate Compactor (A64557)
HONDA Plate...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
1987 Fruehauf MC 307 Insulated 7,500 Gallon T/A Chemical Tanker Trailer (A64194)
1987 Fruehauf MC...
2017 Chevrolet Tahoe SUV (A64194)
2017 Chevrolet...
2017 Land Rover Discovery Sport SUV (A64557)
2017 Land Rover...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
