Absolute newbie- am I being realistic?
   / Absolute newbie- am I being realistic? #21
daTeacha said:
If the guy is going to start from scratch, dig down a ways, lay in heavy rock, go over it with a vibrating roller, lay in another layer of smaller rock, roll that, then lay in a third layer and roll that, and finally topcoat it with a show coat that he doesn't roll, the price quotes sound reasonable. If all you're talking is tailspreading a few loads of crushed local stone, they aren't.
A lot depends on what the job entails and what kind of stone you're going to use, but I had about three times that much drive done from scratch, layering 6-10" sandstone, then medium stone, then crusher run, all packed down with a vibrating roller, for less than those quotes. A couple years later, I had a top coat of blue dolomite put down for appearances and the cost was pretty high compared to the previous work due to the fact that the stone had to come from 60 miles away rather than being local. Whenever I plow the snow, the only thing I tear up is the top coating of pretty stuff. The crusher run that was packed down is doing fine. Makes me wish I hadn't gotten the other stuff put on top.
Are you gonna eventually replace the top layer with the less expensive stuff?
48 Inch Farm Jack (A57454)
48 Inch Farm Jack...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56436)
2021 Unverferth...
John Deere MX8 Rotary Cutter (A57454)
John Deere MX8...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
