Abrupt engine stop when engaging mower
   / Abrupt engine stop when engaging mower #1
Hotmath
Deere la145
After removing the deck to make a repair to the transmission linkage (lubricated the pivot), when I engage the mower, the engine comes to an abrupt, nearly violent stop. I've done tests and observations:
- engaging the mower button with the mower belt disconnect does not cause the stoppage, and the mower pto pulley spins upon engaging.
- the spindles and pulleys and bearings on the deck are new, as are the blades. I can pull on the belt and smoothly turn the blades.
- -after the stoppage, if I remove the belt and try to turn the pto pulley by hand, is seems locked, rotates a small bit either way, then hard stop.
- I've only done this test in neutral
I've worked with 2 ai apps with no luck.
Help!
Thanks,
Chuck
   / Abrupt engine stop when engaging mower #2
No offense, but I get more done when I'm working with my hands and tools. I don't get far with ai apps. It might help to mention what you're working on to start with, and maybe even throw in a few photos of the clutch, belts, ETC that are causing you problems. At this point no one even knows what they would be guessing at.
   / Abrupt engine stop when engaging mower #3
The deck belt isn't routed correctly. It's binding somewhere on the deck.
   / Abrupt engine stop when engaging mower #4
X2 on what Harry and Topzide are saying.
Sure sounds like a belt routing problem, but post the make and model, as well as some photos of the belt routing. Your manual may address the correct routing.
UNUSED FUTURE HYD AUGER (A57193)
UNUSED FUTURE HYD...
UNUSED FUTURE D39 39" HYD TRENCHER (A57193)
UNUSED FUTURE D39...
ATTENTION! PLEASE READ (A53317)
ATTENTION! PLEASE...
2013 F-550 Bucket Truck (A55302)
2013 F-550 Bucket...
2020 NISSAN Versa Sedan (A53424)
2020 NISSAN Versa...
2015 Ford F-250 Knapheide Service Truck (A53422)
2015 Ford F-250...
