Above Ground Water Storage Tank (2,000 GAL)
   / Above Ground Water Storage Tank (2,000 GAL) #11
A modern fire truck pumps water at the rate of 1500 gallons per minute. So u will get about 1 minute 20 seconds of fire fighting from a 2000 gallon tank. Just something to consider.
Do you enjoy swimming pools? An above ground 21 foot round pool is about 10,000 gallons and it would serve a dual purpose and extend ur fire fighting time to about 6 minutes.
   / Above Ground Water Storage Tank (2,000 GAL) #12
Would you be better off with multiple small tanks that are connected? I would think this would allow repair or replacement if one was damaged. Also if one tank fails you do not lose the entire supply of water. I do not know if this is allowed by your requirements.
   / Above Ground Water Storage Tank (2,000 GAL) #13
You do want to plumb the tanks so that you leave most of it for fire; around here, the floats are set on the last tank so that the tanks go from 100%-90% full and refill, with household use taking water from the last tank in the series, the fill goes into the first, and the overflow of the previous tank(s) cascade serially into the tank that the household uses. With that method every tank but the last stays at 100% full, the water is changed, and only the last tank cycles between 90-100%.
I have no advice on how many tanks is optimal; I am more focused on total storage. So, I am going to suggest that you get the most cost effective tanks per gallon that you can for your budget.
But if the fire line has a failure, you lose all of the water.
I have never heard of a plastic tank failure, but I am sure that it happens eventually. Mine are certainly showing signs of age.
All the best,
Peter
   / Above Ground Water Storage Tank (2,000 GAL) #14
If your house is burning beyond what 2000 gallons will put out you might as well step back and watch it burn. The cleanup would be easier.
Yup......in many situations it is best to delay calling the fire dept. for 10-15 minutes, and then call.
   / Above Ground Water Storage Tank (2,000 GAL) #15
Around here, there is an advantage to a concrete pad; ground squirrels can't easily undermine it. They have done this to our tanks and will trigger the replacement of the tanks well before their expiration dates because the undermining is causing the tanks to sink and tilt and starting to stress the pipes coming out of the tanks...
YMMV...
All the best,
Peter
Well, I didn't consider this because 'we' don't have any critters that would undermine a domestic water tank. The only one that might do that would be a rabbit but the tank weight is a deterrent.
Wombats will burrow in a field... nasty, huge holes that can seriously damage a tractor if you don't spot them first.
   / Above Ground Water Storage Tank (2,000 GAL) #16
I thought Australia was overrun with mice.....
   / Above Ground Water Storage Tank (2,000 GAL) #17
2000 gallons is quite a bit for a residential structure fire unless as some say it is already gone. In my decades of firefighting I used a 750 gallon tank to extinguish by far the majority of single room and contents fires.
One thing to remember is if a fire engine connects to a tank and "sucks" water out without adequate venting they can collapse the tank. If you use a gravity fed male 2.5" fire thread (not NPT) you will not get a very high flow from the tank if your tank is only 4' high. Add to that a length of hose with a kink and you have even more issues.
To determine the pressure you will have, take the total feet of "head" (top of water level to nozzle in feet) and multiply by .434 to get PSI. If you have a tank with a total height of 10', at the base you will have 4.34 PSI. That is the pressure to overcome friction loss and have enough to get anything out of the nozzle. Remember as the tank level drops, so does the PSI from head pressure.
If you want to know what you can get out of a pipe using gravity, use the rough formula 30 times the diameter of the tip in inches squared, times the square root of the pressure. A 10' head with a 2.5" pipe would flow around 375 GPM with little pressure left to use. At 5' of head (tank half full) you could expect maybe 275 GPM.
When moving water using gravity there is a lot to consider. Pump it.... and use every bit of it.
The common flow for a 1.5" combination fire nozzle is 100GPM at 100 PSI at the nozzle although that can vary. There are smaller nozzles fire departments frequently carry but they are seldom used on a structure fire. In order to have a firefighting capability you will need a sufficient pump at the tank. And have it ready to work in seconds.
Sorry for the long post here.
   / Above Ground Water Storage Tank (2,000 GAL) #18
im surprised they will agree to hook up to it. here, the fire dept wont hook into residential holding tanks cause they cannot guarantee the tank isnt full of crap that could wreck their equipment.
Our FD will bring water out and refill 1K gal reservoirs if you agree to let them pump from it if needed. Not the same thing as a holding tank though.
   / Above Ground Water Storage Tank (2,000 GAL) #20
Looking to install an above ground water storage tank for rural wildfire fire suppression. Looking at 2,000 GAL +/- tank. The local FD said they will fill it up for free and they can connect their nozzle at the base and pump it out if needed.
They have black/green plastic tanks available for around $1,300. Any advice?
I will also have to lay a footing down (18' frost depth) and a concrete pad. 4 or 6 inch? Any advice?
I had 3 tanks in Texas, hooked up for rain water collection, 2 5,000 tanks and one 10,000 tank. I had them on level ground, no concrete pad. So pads aren’t needed, but certainly make the set up look nicer. I never had an issue with squirrels or any other rodents. $1,300 seems like a good price on the tank, mine were black and were built for the outdoors. The tanks were there when I bought the farm, worked well for 10 years and were solid when I sold the place.
10x16.5 Tire Assembly (A50397)
10x16.5 Tire...
1990 Cadillac Sedandeville (A48836)
1990 Cadillac...
KUBOTA L2501D TRACTOR (A50459)
KUBOTA L2501D...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
40' CONTAINER (A50459)
2017 CATERPILLAR DGT LGP DOZER (A50505)
2017 CATERPILLAR...
