plowhog
Elite Member
- Joined
- Dec 8, 2015
- Messages
- 3,153
- Location
- North. NV, North. CA
- Tractor
- Massey 1710 / 1758, Ventrac 4500Y / TD9
I have an above ground diesel tank. About 300 gallons. There has been a small quantity of fuel in it for many years. I believe I need to purge the old fuel and replace it before using?
There is one fuel line (underground) to a diesel heater in the residence. The heater also has not been used for many years. I know it needs priming before even trying to start.
There is also an old Tokheim manual fuel pump on the top of the tank. I believe it is a model 786 (or similar.) A google search shows this is a very old unit with limited parts availability. I haven't tried using the pump but would be surprised if it works?
I'd like to start using this for off-road diesel to fuel my tractor and equipment. But I believe I should clean it out, or at least purge the old fuel. Any suggestions or recommendations about how to freshen up this tank so I can reliably use fuel from it? (I would probably filter the fuel into my tractor using a Mr. Funnel.)
