About to pull trigger on JD 4300....
   / About to pull trigger on JD 4300.... #11
J long, you have to be registered in order to post pictures and attachments. Go ahead and register and join the group. It's painless./w3tcompact/icons/wink.gif
   / About to pull trigger on JD 4300.... #12
I replied before, but was not then registered, so I could not provide the side by side pictures that I took when trying to decide between the JD 4400 and the NH TC35D. I went with the 35D and believe it was the most tractor for the money. Both were very close on paper, but when looking at the side by side, the decision was pretty easy. I am now registered, so here are the pictures. Hope this helps. Good Luck. J Long
   / About to pull trigger on JD 4300.... #13
J.Long,
Must've had the lens cap on the camera, cause all we're seeing is gray! /w3tcompact/icons/crazy.gif
   / About to pull trigger on JD 4300.... #14
My previous attachment with the pictures exceeded the 150K byte limit on attachments, so maybe that's why it did not work. Here is a single picture. Thanks for your patience. Jim
   / About to pull trigger on JD 4300.... #15
Nice picture!
Boy, I wish I had a dealer that sold both JD and NH so I could compare them side by side /w3tcompact/icons/sad.gif. About 2 hours from here is a dealer that sells JD, NH, AND Kubota! I'm seriously thinking about going up and spending the day/w3tcompact/icons/smile.gif. What's the down side of one dealer selling all three? Are they going to push whatever isn't selling right then? Anybody have any experience with that situation?
   / About to pull trigger on JD 4300.... #16
Nice picture. Do you have any more comparing the two? I was torn between a TC 40D and a 4410. I drove both several times, but never got to compare them side by side like that. I couldn't quite tell how much difference there was in size between the two.
--Brad
   / About to pull trigger on JD 4300.... #17
I always figured the JD 4300 was closer to a NH TC33 than to a TC 35
2005 Toyota Tundra Limited Crew Cab Pickup Truck (A48081)
2005 Toyota Tundra...
2018 HINO 268 26FT BOX TRUCK (A51222)
2018 HINO 268 26FT...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A51039)
2021 John Deere...
2006 International 4400 LP Ambulance (A50323)
2006 International...
2001 International 3800 4X2 School Bus (A50860)
2001 International...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
