about those fluids....
/ about those fluids.... #1
cin
Kioti LB2204 W/Loader
I realize now that the 19 folks that have looked at my post must think i'm some kind of dork :) no worries, i'm not. I just didn't want to put the wrong fluid in the wrong place, i've decided to just suck it up and go to the dealership and get the info i'm seeking. thanks anyway for at least reading my post.
/ about those fluids.... #2
Welcome to TBN. What kind of tractor do you have?
hello, I have a LB2204 kioti and I'm more concerned about the "gear shift" box and what fluid to put in there...thanks.
/ about those fluids.... #4
Sorry I cant help with the Kioti I have kubotas. I would search for a shop manual and parts manual as well as the operators manual. Most modern tractors use the hydraulic fluid for the transmission gear box. Is your machine a HST? Sounds like a silly question but my L4400 HST has a clutch and 3 gear ranges for the HST.
thanks anyway...I'll let you know how it goes when I find out!
cindy
/ about those fluids.... #6
cindy
Is your machine a Hydrostatic Transmission meaning you push a pedal to go forward let up to stop and push a pedal to back up and let up to stop?
no it's not like that...have to shift for different speeds. there is a high and low 4 gears. make sense?
/ about those fluids.... #8
I searched Tractor data and this appears to be an older Kioti .
If this is correct you have a standard not HST and you would most likely use Hytran fluid this is a multipurpose fluid for the Hydraulics and the geared transmission. I would consult the Kioti dealer though. There are manuals available for the tractor.
thank you again. my list of fluid includes the following that came with the tractor and as silly as this sounds i just wanted to know which one goes in the gear compartment...."tran/hydraulic: JD-303, front differential GL-5 85w-90, coolant: Napa 50/50 and Engin: Chevron Delo 15w-40 Diesel Oil" I know it's not the coolant, and i know it's not the chevron 15w-40 but i'm unsure about the other two....
/ about those fluids.... #10
The JD 303 tran / hydraulic goes in the common gear / hydraulic sump and it would probably be the largest container of oil that you have. The 85w-90 would go into the front differential of a 4WD tractor. I assume the dealer sent you home with the fluids and did not tell what went where. Most tractors transmission gear box shares the same oil as the hydraulics. Is your tractor a four wheel drive? More details would help make sure what goes where or have you solved this?
yes it is 4WD. I only have a "list" of the fluids i'm going out today to actually buy them.
/ about those fluids.... #13
Your LB2204 has a common reservoir and it will take the hydraulic/trans fluid.
You fill it on the top of the transmission hump.
I'm thinking you have a sight glass under the floor board to check the fluid level....If my mind serves me right the sight glass should be on the passenger side.
thank you! I will check for that window in the morning.
/ about those fluids.... #15
Is it possible that it does not have a sight glass?
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
UNUSED MOWER KING-AGT SAII100 (A64281)
UNUSED MOWER...
2016 BOBCAT T770 SKID STEER (A64279)
2016 BOBCAT T770...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2020 John Deere 560R Premium Round Baler (A63111)
2020 John Deere...
2014 Freightliner Coranado 132 Daycab (A62679)
2014 Freightliner...
