About the Cement Mixer
   / About the Cement Mixer #1
indhrasena.reddy
Hi, All i have a cement mixer i was wondering if my remote valve could work the single acting cylinder i have on the mixer, i have two ports on the back of my tractor i was wondering can i just use one to work the cylinder on the mixer?
   / About the Cement Mixer #2
Yes, you can use just one of the 2 work ports on your valve, but it is not
ideal. I did it that way when I first got a MIXER80 for my 3-pt. The
single-acting cylinder depends on gravity to dump, and it did not always
work. I converted to a double-acting cyl by simply converting the
breather to a hose fitting.
If you DO operate the valve with just one hose connected, the relief
valve will operate briefly while the cylinder dumps.
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Glenco Disk Chisel (A50515)
Glenco Disk Chisel...
Kubota SVL95-2 High Flow Cab Skid Steer (A52748)
Kubota SVL95-2...
2010 Toyota Camry Sedan (A50324)
2010 Toyota Camry...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
