About the Cement Mixer
/ About the Cement Mixer #1
indhrasena.reddy
Hi, All i have a cement mixer i was wondering if my remote valve could work the single acting cylinder i have on the mixer, i have two ports on the back of my tractor i was wondering can i just use one to work the cylinder on the mixer?
/ About the Cement Mixer #2
Yes, you can use just one of the 2 work ports on your valve, but it is not
ideal. I did it that way when I first got a MIXER80 for my 3-pt. The
single-acting cylinder depends on gravity to dump, and it did not always
work. I converted to a double-acting cyl by simply converting the
breather to a hose fitting.
If you DO operate the valve with just one hose connected, the relief
valve will operate briefly while the cylinder dumps.
2003 John Deere 567 Megawide (A64126)
2003 John Deere...
Fork Extensions (A65640)
Fork Extensions...
2021 DITCH WITCH HX30 TOWABLE VACUUM TRAILER (A63276)
2021 DITCH WITCH...
Bush Hog RDTH84 (A64126)
Bush Hog RDTH84...
Pallet of Misc Sling Webbings (A64127)
Pallet of Misc...
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
