?? About octane for mowers and chain saw
   / ?? About octane for mowers and chain saw #131
Too low octane will ruin the engine $$$$$$$$$$$$$$$. A little extra octane for insurance is low cost peace of mind.
In modern cars with anti-knock sensors and computers, it's almost a non-issue. The computer can adjust the timing on the fly to compensate. If you put in what the manufacturer recommends, its a non-issue.
As for small engines, I've never had to change the timing on any stock engine, ever. Old cars with points? Yes. Putting the distributor back in the corrrect place on my 93 Suburban? Yes. My Yamaha RD400 two-stroke twin drag bike with many stupid crazy mods? YES! My Poulan chainsaw? NO! My Craftsman chainsaw? NO! Weed eater? Snowblower? Tiller? Pressure washer? Log splitter? NO NO NO. hahahaa !!! E10 of any octane rating is a non-issue if you use gasoline that is rated at the octane level specified by the manufacturer.
   / ?? About octane for mowers and chain saw #132
The linked Briggs site says that 15% ethanol is NOT recommended. If 15% is bad so is 10% in my book. The engines may TOLERATE 10% alcohol but that does not mean it is good. That link to me proves ethanol is bad.
I run 10% in my vehicles that get driven every week but not in an engine that sits and draining fuel is too time consuming.
   / ?? About octane for mowers and chain saw #133
How did you measure that performance?
Ease of starting and staying running when engaging the PTO on mowers with the engine rpm at idle, lugging ability when climbing my pool/pond banks of ⅓......30^ ish; some equipment I bought with electric start for ease of starting kick right off with the pull rope so I don't need/use the electric start function I paid an extra 100 bucks for when purchased. Ease of starting on 2 strokers that sit for long times between starting, revving rate when goosing unloaded, power going through limbs on chain saws with nothing changed but the fuel.
   / ?? About octane for mowers and chain saw #134
That's all subjective. I know many of us, including me, tend to think something is working better when we make changes, however, it's not a measureable thing. It's a feeling. Hey, if it's working for you, that's what counts. I just like to see things measured once in a while, to see if I'm nuts, or I really am feeling an actual difference.
   / ?? About octane for mowers and chain saw #135
Hey, if three beers are bad, so are two. Right? :laughing:
   / ?? About octane for mowers and chain saw #136
Now why did you have to do that? It's obviously the opposite when it comes to that type of alcohol... if 2 beers are good then 3 beers are better. :drink:
   / ?? About octane for mowers and chain saw #137
Greetings MossRoad,
I think what you are missing in the discussion - is just how much you are adapting your methods to deal with E10. I get it - you live in South Bend, so you have some cold weather like we do in Wisconsin. And I get it that you've been doing this for years. But what you are missing is that for many people, they don't have every vehicle with a computer and a no-knock sensor in it. The idea of buying gas in sealed cans - is just nuts when you don't have to. Now maybe in your area of a 15 mile radius - you don't have E0 outlets and so you are forced to do what you do . . . but that is certainly not the situation for many others.
I go thru mixed (2 cycle) gas in spurts where I can use as little as 2 gallons in a month or 2 gallons in a day. 2 cycle gas for lawnmowers, snowblowers, weed whackers, chain saws, motorcycles etc.. You mention things are subjective - but I've over time made them quite objective. Lets take some examples:
1. I can take E0 gas and e10 gas bought on the same day at the same location - both "rated" at 87 octane and run each of them in my Pickup (Silverado 2 wd SS with an LQ9 performance engine in it). In each case before running the traveling circuit - I had the fuel tank virtually empty and the circuit was run on the same highways, in the same combination of directions and weather conditions and speeds. The result was 22.1 mpg with the E0 and 19.8 mpg with the E10. Because my engine is a 10+ compression engine - the E10 87 octane caused some power delays and weaknesses or some mild knocking, meanwhile the E0 showed no such indicators.
2. I don't know about you - but for me - I have a 4 cycle 8700 watt gas generator (Honda engine) - that stands at the ready for remote tool usage or power failures. I can't predict when I might need gas that is 30 days old or less. I certainly can't afford to have "sealed can" gas, I have to keep gas at the ready as most people do when they have gas powered tools or generators - or end up like the puppy's lined up at the gas station lines with 1 single 5 gallon container for their power outage situations. If I had to babysit my gas supply like you do with a 30 day requirement of gas aging - I'd be caught with my pants down many times each year - and I have no desire to run to the gas station right when everyone else is doing the same thing. Do I use E0 87 octane in everything I can - yes. On long trips do I sometimes put E10 in my truck when I have no other choice - yes - plus I add additives to try to "fix its problems".
3. People say they use premium gas at $1 a gallon more so they can get E0. But its also important to recognize that many many stations with premium gas are still not E0 - they are E10. If there isn't a sticker on the pump saying non-ethanol gas or "off road gas" - then its E10. No sticker - no E0 that's a government inspection requirement.
4. I can take my favorite weedwhacker. With E0 87 octane it starts in 2 pulls and 3 if its been not used for weeks. I can dump out the E0 and put in E10 and if cold it requires 4 or 5 pulls plus diddling with the choke and revving it up the first 2 minutes - and if I stop whacking and I don't keep my finger on the trigger to some extent - it may kill about half the time - no so with the e0. Now that whacker has had 0 adjustments to it since I bought it 5 years ago.
MossRoad, my point is not to get you to change your mind - my point is - you don't seem to recognize just how much you have adapted everything you do relating to gas - to fit E10 weaknesses (except the air pollution issues of ethanol). I like Tennessee/Kentucky Bourbons - but I don't want to run alcohol in my equipment because its not "smooth" like Bourbon - its "corn squeazings" which is not lubricating oriented its very harsh. Ask any pipeline company what they think of ethanol - and you'll get an earful - because it forces them to scrub their lines often where they run ethanol thru them. Or ask service techs that work on small engines. You don't get "green carburetors" from E0 - you get them from E10. And "green" doesn't mean environment - it literally coats the carburetor components and often requires replacing the carburetor all-together.
Yes some things are quite subjective in life - but that doesn't mean everybody is and it doesn't mean every opinion is subjective - opinions can be factual.
Here's one way you can see it from a whole different viewpoint. People want to argue about what manufacturers recommend for their engines - but then they conveniently forget to note that those recommendations from manufacturers are based on what is "the legal norm" and available norm". If you look at instruction manuals done 20 years ago (still in the E10 era - you will see different recommendations. REAL 87 octane E0 octane gas today is made from actual 87 octane petroleum distillates. But 87 octane E10 in big percentages is now currently mixed as 84 octane gas and then ethanol is added to acquire the other 3 octane rating. But alcohol octane is different than petroleum octane in its properties for burn compression - which is why often you now see small engines recommending 89 octane because of e10.
I'm always open to new thinking and supported input.
jmho
P.S. I never use Stabil for anything except my "emergency backup" 5 gallon containers of generator fuel.
   / ?? About octane for mowers and chain saw #138
Greetings MossRoad,
jmho
Why do you keep talking to me about buying gas in sealed cans and a 30 day time limit? I do neither of those.
   / ?? About octane for mowers and chain saw #139
Ethanol in the fuel makes the engine operate leaner and more prone to detonate on 87 octane ethanol vs 87 octane no ethanol.
   / ?? About octane for mowers and chain saw #140
And the sky is blue.
It's a non-issue in modern cars. And a non-issue in small engines designed to run on E10 87 octane fuel.
Welcome to the Ranch Metal Sign (A57454)
Welcome to the...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
2008 TEXAS BRAGG GOOSENECK FLATBED (A58214)
2008 TEXAS BRAGG...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56438)
1992 Talbert 70...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
