A3.135 piston question
   / A3.135 piston question #1
curt3969
Massey 35
Hello, I tried to search this with no luck. I hope someone can answer this for me. As I was installing my new rings on the pistons. It is a 5 ring piston by the way, I noticed that the 4th ring from the top (oil ring) is different from the ones on the old pistons. The new one is not a solid cast ring but a squigily one with a thin ring on top and bottom of it. Kinda what you would see on a small block chevy. But the kit was listed 5th 4th 3rd and so on. All the other rings are the same except the 4th ring. Has anyone seen this before?
   / A3.135 piston question #2
Is this your piston? - kid
   / A3.135 piston question #3
That's a oil control ring.
I have flat top pistons. But the ring positions are the same. I have the vertical injectors.
Sorry its is a A3.152 perkins. 1962 massey 35. Thanks for the input.
   / A3.135 piston question #6
Curt, I'll scan that page and sent it to you in a private message in few minutes. -robert
   / A3.135 piston question #7
Right, the direct injection AD3. engines had the dished piston top.
Unfortunately I am just now finding out more about one of my AD3.152's pistons than I ever expected to know. It drew at least part of #1 liner into the crankcase. Made kind of a mess. Part of the liner ended up being crunched (pulverized) at the head.
Thanks, The Manual I have says its a spring loaded laminated scraper ring. Thats fine, but I need to find out if this "new ring" can be used to replace the original. This whole rebuild is due to piston failure after a rebuild. I will try to post a pic of the old and new tomorrow and see what you all think. I bought this project due to excessive oil consumption. Turns out the lands between the rings were all busted up. I just want to be sure that this scraper ring is correct.
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
2019 Komatsu WA380-8 Articulating Wheel Loader, S/N A74991, PIN# KMTWA130VJNA74991, Turbo Diesel (A59076)
2019 Komatsu...
2015 Dodge Charger Sedan (A56859)
2015 Dodge Charger...
2016 24' Iron King Flatbed Trailer (A57148)
2016 24' Iron King...
UNUSED I/A F10 TILT 10' HYD TILT BOX SCRAPER (A57192)
UNUSED I/A F10...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
