A weird one happened to to my JD 4400.
   / A weird one happened to to my JD 4400. #1
Cactus
I was brush hogging on a bank yesterday ,I would back down the bank and drive back up because the bank was too steep to mow any other way. While I was mowing I momentarily heard a noise and then never heard anything else out of the ordinary. I continue mowing and I noticed my 4wd was not working.I check to make sure the 4wd is engaged to which it was.
I look under the tractor and grass/hay is wrapped around the drive shaft so tight I had to use my orbiting grinder to remove it. Under further investigation I find that the coupler/sleave splines on the front of the drive shaft ( end towards the front tires) is worn and the splines on the front end of the drive shaft are worn out. The new drive shaft is a little over $80.00 dollars and the couplers/sleaves are a little over $13.00 a piece. The splined piece that sticks out of the front end of the tractor is worn some but not as bad as the coupler or drive shaft is.To replace it will take a complete tear down of the front end which I feel I will probably have to do eventually to replace one piece. The rest I will do Friday and get my self back in business for now. The noise I heard was the splines on the drive shaft spinning in the sleeve and destroying the splines when the grass wrapped around the drive shaft. Up until then the 4wd had been working fine albeit this past winter when the rear sleeve came loose on the drive shaft and I had to put it back together while I layed in the mud.
   / A weird one happened to to my JD 4400. #2
It's all my fault. So Sorry!
See, this past weekend I was under mine looking at the front. I saw the front propeller shaft exposed up there. I had one like that get wound up in weeds once. so I was wondering if I should fab a cover for it. I wondered if anyone ever had a problem with theirs.
You are the gunea pig.
Sorry.
No live animals were used in testing of this theory.
I would have thought the drive shaft would hold up better than this.
   / A weird one happened to to my JD 4400. #4
I've seen it even on a 2210,,,
tall grasses just got wrapped around the mfwd shaft... at the transmission end. eventually pushed the seal in and sprung a leak..
seems to be a good place to check every once in a while
and see if stuff is binding up under there anyplace.
   / A weird one happened to to my JD 4400. #5
My Yanmar 186D had a cover (justr like a pto shaft safety shield) over the propellor shaft. Wonder why there isn't one on these... /forums/images/graemlins/confused.gif
</font><font color="blue" class="small">( <font color="blue"> You are the gunea pig. </font> )</font>
Thats ok...someone has to do it. /forums/images/graemlins/frown.gif
GEARMATIC WINCH CABLE DRUM (A58216)
GEARMATIC WINCH...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2020 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
1759 (A58375)
1759 (A58375)
CHALLENGER MT 525B TRACTOR (A58216)
CHALLENGER MT 525B...
PALLET OF WOOD & DOORS (A58374)
PALLET OF WOOD &...
