A tale of two 5yd dump trucks....
   / A tale of two 5yd dump trucks.... #11
I am a biased Cornbinder man. The Loadstar is heavier built from the ground up. Parts are always obtainable in wrecking yards for either of these trucks. The Loadstar will have either a 304 or 345 in it. Not a lot of the 1600 trucks came with a 392. I would make sure they both have power steering and crawl under them, check the Emergency brake assembly and dash components and interior for wear or abuse. IHC doors can be in bad shape. The cowl right under the windshield is prone to rust and rot, INSIDE, ie the fresh air vent going in to the cab. That can be rotted badly. Dash parts and switches for the Chev will be easier to find new. The most important thing if you buy the International, take the serial number to a dealer, pay them twenty bucks or what ever they want and get the factory line setting sheet. It tells what each component is and is the key to replacement of parts and components in the drive train.
   / A tale of two 5yd dump trucks.... #12
You can get a line setting ticket and get a good laugh from international if you try to buy something. Loadstars are long time obsolete. Need a good heavy duty truck parts place around. I wouldn't worry about the cost of tires because you can feed either truck used tires. Check frames, check suspension with prybar, jack up steers and check king pins, check steering play/box. Trucks at that age are survivors been to heck and back. So lucky for you, you can't show them any new tricks.
   / A tale of two 5yd dump trucks.... #13
Since you live in the beautiful state of Michigan, you should also talk to someone that owns/drives a truck like that on the roads. Some guys are ditching the older trucks and buying newer because of State Police inspectors. They have really clamped down on making sure the trucks are 'road worthy', especially when they see something older on the road. If it is something you are just going to use on your property, or close by, is one thing.
   / A tale of two 5yd dump trucks.... #14
I've got an old Loadstar, a 1700 awd. It has to be the toughest thing I've ever owned. I was looking for a 1 ton with 4wd so I could plow my driveway with it. But prices were through the roof. It came with a 345, from what I understand the 392s were all 4 barrel, while most 345s were 2 barrel. The engine sat for years so it needed to have the valves reseated (possibly upgraded for unleaded gas) but I never got around to it. A local highway department had an auction and I picked up an old hose truck that they turned into a truck to spray to keep dust down on the dirt roads. I did an engine swap only to find out that it had a 446 in it so I have lots of 345 and 392 parts laying around that will go to the scrap yard when the price of steel goes back up. I haven't needed anything lately but in the past I found several salvage yards that were full of old loadstars. There's a lot of old IHC school buses out there. Yards love to keep them to store used parts in. I think you'll find that the old Loadstars were built to be a truck, not fast and never going to be fast. But the engines have probably twice the steel in them.
Well, my neighbor has one, but he never goes far. My other neighbor has several big rigs and does mostly long-haul work, but some local as well...he had an older tandem dump he sold a year or so ago. I can ask both of them, but I'm really not planning to go far with it.
That reminds me of the old Mack mixer truck I drove for two summers....it maxed out at 63mph and I was fine with that! I'm definitely not expecting anything fast, and having been in an accident with a car who ran into my mixer (ran a red light), I'm never in a hurry when I'm driving anything big....they all lived, but it was within inches of being fatal.
   / A tale of two 5yd dump trucks.... #18
Anybody have diesel loadstars?
   / A tale of two 5yd dump trucks.... #19
Back in March/April I picked up a nice 1982 S-1900 with the DT-466 in it.
   / A tale of two 5yd dump trucks.... #20
Compare prices of the same wear parts: brakes, clutch, tires, u-joints, etc.
Parts availability in your area.
How it feels to drive.
Bruce
2X on all points
John Deere 335 Round Baler (4ftx4ft) (A52748)
John Deere 335...
2013 Dodge Charger Passenger Car, VIN # 2C3CDXATXDH646719 (A51572)
2013 Dodge Charger...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
Year: 2014 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A51694)
Year: 2014 Make...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
