A stuck clutch?
   / A stuck clutch? #1
dougrock36
MF50A
I'm going dane dane dane.....am I gonna have to split this thing? I've got a Massey 1020...luv the little guy, done great service for me. Today I jumped on, it was in First gear slow mode, the clutch was pressed in, started the tractor and
there she was moving forward on it's own!! No matter what I did with the clutch pedal she moved forward !! Any thoughts? I found a happy place for the machine and had to stop it by turning the motor off, did not enjoy doing that.
grrr grr grrr.....sorry, guess nothing works perfect forever! Any idea's be greatly appreciated.(no no not want to split the thing!)
   / A stuck clutch? #2
Sounds like a clutch problem to me...before concluding the worst, check the linkage and make sure you are doing something when you press the clutch pedal. Maybe the linkage is loose or ?
   / A stuck clutch? #4
Gotta be at least 50 threads about stuck clutches and hoe to repair. Do a search first.....
   / A stuck clutch? #5
I used to have a 1030 that I inherited from my Dad that would do the same thing. That tractor had an arm that you could engage to keep the clutch pedal down when not using the tractor. If I forgot to tie the clutch pedal down, I could experience the same “surprise” that you did. In that event, I would drive the tractor around, and eventually the clutch would become “unstuck”. Thereafter, I would remember to “tie down” the clunch pedal!
Jack
   / A stuck clutch? #6
My Yanmar has a lever to hold the petal down and I made a lever for the New Holland. I need to check if I used them last time I put them up.:unsure:
   / A stuck clutch? #7
I just posted "stuck clutch fixed"
I warmed mine up at high idle, gave up and let it cool tried one more time, broke free on the third tug.
Tractor in high gear, clutch blocked down, by myself so I pulled up hill.
Gentle tugs with f150.
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2004 AGCO Gleaner 3000 Corn Header (A56436)
2004 AGCO Gleaner...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
TANK MANIFOLD (A58214)
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A60429)
2021 CATERPILLAR...
