A simple oil change.....Negative
   / A simple oil change.....Negative #1
MotorSeven
Elite Member
NE TENN (Hancock Co)
Kioti DK40SE Hydro
I had everything ready, so I figured on about 30min. Warmed it up, slid a drain pan under then removed the drivers side drain plug. When I removed the off plug, it had a lot of resistance to it:scratchchin:. No metal came off on the threads so I pulled the old filter, spun on a new one then replaced the plugs. Yep, the off one was stripped:jaded:. Now I know what y'all are thinking, that I went Gorilla on them, but i know better and only "snug 'em".
So I had to run into town and get a self tapping over sized-plug. It was impossible to start by hand, so I used the air ratchet to get it going, then finished by hand. The new plug has a smaller removable piggyback bolt inside of it so I don't ever have to take the self tapping part out of the pan(good). But, the second bolt hangs down a lot further than a stock one..about an inch(bad)....so I really need to think about making that belly up pan this winter.
I'm really wonder why a aluminium oil pan is used by Kioti(and others). Steel would probably be cheaper and a lot tougher. At the very least the aluminium one should have a steel insert for the drain plug...jmho.
   / A simple oil change.....Negative #3
and more expensive when they sell you a replacement for the one that strips out.. ;)
   / A simple oil change.....Negative #4
It will get worse.
Many cars today use plastic oil pans. I imagaine they will work down to farm equipment before too long.
   / A simple oil change.....Negative #5
yep.. i see composite oil pans in yard equipment applications already...
   / A simple oil change.....Negative #6
I agree same thing happened on my 2008 DK 40se.PI$$ poor design IMHO.coobie
   / A simple oil change.....Negative #7
It will get worse.
They would probably hold up about as good as my cracked hood and fenders on my JD :mad:
   / A simple oil change.....Negative #9
imho.. bad idea.... same as plastic sheet metal.. :(
   / A simple oil change.....Negative #10
Why wouldnt a little anti seize compound take care of this
2013 INTERNATIONAL MA025 ROUSTABOUT (A52472)
2013 INTERNATIONAL...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
199049 (A51243)
199049 (A51243)
Polaris ATV (A50324)
2013 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2013 JACK COUNTY...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
