A shed is born,finally
   / A shed is born,finally #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Just a few pics of my garage/shed going up.There was not a level spot on the lot to build on so it took lots of bank run gravel and a retaining wall to make it work.
http://i24.photobucket.com/albums/c29/shenders/barn016.jpg
http://i24.photobucket.com/albums/c29/shenders/barn020.jpg
http://i24.photobucket.com/albums/c29/shenders/barn015.jpg
http://i24.photobucket.com/albums/c29/shenders/barn001.jpg
http://i24.photobucket.com/albums/c29/shenders/barn018.jpg
the retaining wall is not in this set of pictures.Twelve loads of bank run so far.The shop is needed to continue with this project.Too cold to work on the carport anymore.
http://i24.photobucket.com/albums/c29/shenders/vettenew022Small.jpg
http://i24.photobucket.com/albums/c29/shenders/vettenew024Small.jpg
   / A shed is born,finally #4
That is going to be a nice one ! And I also like the Corvette , is it a 1969 ? , I would love to have a 69 - 427 to build, Good luck to ya!
   / A shed is born,finally #6
Hi Bones. Your toys will be happy they have a place to call home.;) What size is going to be? Did you use cement to set the post or tamp dirt back in around the post. Seen it done both ways and from the pics the area around the posts looks clean. Also, I see where the tall timbers Maryland comes from. You have some monsters in those woods.
EL
Thanks elalexander.We got some bigg'ens here.The pole barn is 30WX36LX12.4H walls.The poles have moulded plastic pole protectors that do fit tight.They are about 5 ft tall then two 80# bags of concrete in the bottom of the hole (dry) then fill in with remaining dirt and tamp down real good.Moisture from the ground is supposed to harden the concrete over time.
Just hope one of those trees doesn't take a liking to my shed.
   / A shed is born,finally #8
Looks like your building a very nice home for that vette!!!!
I like those plastic sleeves on the poles. Did the contractor do that, or are they like that from the supplier? I've never seen them before and I'd love to learn more about them.
Are you going to pour a pad to work on when it's all built?
Is there a man door to get in?
Thanks for the pictures,
Eddie
Hi Eddie,was waiting for you.The post protectors came in a bundle and they drove them onto the posts and secured with screws that had rubber washers on them.Keeps water from coming through the protectors.There is a man door on the left front-side as well.A slab will come later and I will need a bit of fill first looking at the bottom boards.I tried to grade it level but had no laser so this is what I get.Open to all suggestions on the best way to fill/not fill and do the slab.Thanks.
   / A shed is born,finally #10
Afternoon Bones,
Gee, shouldnt you have done all the pole work when the grass was green with a nice warm breeze ;) :)
All kidding aside, very nice and Im quite jealous :( you see I am saving for a barn/workshop and Im still considerably on the short side $$$ unfortunately.:confused: Any day now any day :)
Good luck with your new digs !:)
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
ALLISON TRANSMISSION (A53843)
ALLISON...
Ford Super Duty FX4 Pickup Truck Bed (A51691)
Ford Super Duty...
5TH WHEEL HITCH (A53843)
5TH WHEEL HITCH...
DOWNING MANUFACTURING BITUMINOUS APPLICATOR (A51406)
DOWNING...
