a sharp chain!
   / a sharp chain! #31
How important is chain tension? I think I tend to go a bit tighter then others I know. There seems no good way to really judge this, other then by feel. Pulling on the chain to see how many teeth come out of the grove seems somewhat imprecise for something I imagine to be quite critical.
Very important, and I think too tight is perhaps worse than too loose. I just hold the tip of the bar up with one hand and turn the tensioner until the chain comes up to meet the bottom of the bar. Tighten up the nuts slightly and then give the chain a pull to make sure it moves freely and doesn't slacken any. If good, tighten up the nuts completely, if not, adjust a little more. Might take 1-2-3 iterations to get perfect. You should be able to flick the chain and it will spin freely with no resistance.
Also, be sure to adjust tension with a cold bar/chain as much as possible, and do not re-tighten fully when the chain heats up and expands. If you do, it can be way too tight when it cools down, and actually bend the crankshaft of the saw. Stihl pre-stretches their chains, so new chains will only be expanding from heat. With other brands, a new chain may stretch during initial use, so you might need to play a delicate game of taking up slack but be careful not to go too tight. If I ever have to re-tension a hot chain, I know it should be left a little looser than a cold chain.
   / a sharp chain! #32
Get yourself a file guide.
Follow the instructions (designated angles and pitch) on the chain box. Be consistent. Sharpen often. Get a vise, a bench or someplace you can hold the saw steady for consistency. I always do the Michael Jackson thing with one glove so I can grab the chain and hold it tight and turn it. If you get it wrong, no problem. You'll know (no chips, just dust), so try again. Flip bar. People have a tendency to cut sideways (either because of applying pressure or uneven sharpening, etc, ?), a bar's "rail" will wear uneven on one side, causing more exaggerated sudeway cutting. Flipping bar helps this. Wear safety chaps.
Actually, don't put the spinning end into the tree.. When top side of the end of bar hits objects, this is when you get kick back. Not good.
All good advice here, well said. :thumbsup:
   / a sharp chain! #33
I am currently working on a white oak about 24 feet long and 28 inches in diameter, I am starting to see the sawdust with the confetti - so I should pull that chain and set it aside, or since I pay to have them sharpened - just use it till it will not cut anymore?
I just bought a 2 pack of chains so I have spares.
You will reach a point where the chain is so dull the saw has to work much harder and it will run hot. You want to avoid that situation, as it's not productive for you and it's not good for the saw. If you can field sharpen a chain with a file, do it as soon as you see the confetti starting to break down. If your only option is to change out the chain, then I'd probably wait until the dust and confetti are about 50/50. That is before the chain becomes totally useless, but after you have gotten some good life out of it.
Of course, how quickly a chain dulls depends on a lot of things. You can wreck a brand new super-sharp chain in a heartbeat if it hits the dirt or runs through dirty wood on the very first cut. I am sure that has happened to all of us. I usually just shake my head, cuss a little, and pull out the file.
   / a sharp chain! #34
Yeah there is usually a little head shaking and cussing going on while I'm cutting wood too.:hissyfit: I have a 5 gal bucket I carry with me anytime I go into the bush with my saw. In the bucket is a screw driver and a wrench to loosen the bar nuts. A flat file and a couple chain files in a plastic pouch. A couple aluminum wedges and a small hatchet. I also carry chain oil in the bucket along with a can of gas/oil mix on the side.
One thing about files is you can dull one of those about as quick as you can dull a chain if you handle them wrong. don't let them bang together or put them in a place where they can roll around in contact with other medal objects. I had a old friend that said to not even touch the file with your fingers because it will cause it to dull quicker. I don't know if that is true but he showed me how to hold the file when filing the saw to make it last as long as possible one hand on the wooden handle and the other lightly on the very tip of the file to maintain stability.
What I do when cutting wood is I lightly run the file around the teeth every time I put gas and oil in the saw. It's always easier to keep the chain in good cutting order if you sharpen it before it gets really dull and out of shape. When cutting medium sized wood, 12" to 17" stuff by the time you have run a tank of gas through the saw you have cut a pickup truck load of wood once it is split. I found this out back when I was selling firewood. When the saw ran out of gas I would stop and then split it with an ax and a wedge then throw it on the truck. Pretty much always I would have a good load with a few sticks left over for the next one. I could cut split and deliver 4 loads a day sometime 5 or 6 if I was cutting good wood that was clean and split easy and didn't have to haul it too far. Doing it this way kind of broke up the operation into parts where it made the day a little easier. I hated the splitting part and loading the truck more than anything so it broke that part up. The cutting part was my favorite part but that went by so fast I didn't get to enjoy it that much.
   / a sharp chain! #35
When sharpening with the file:
In the file-holder / jig you can set the file clamp a little less on tightness so the file can be rotated. Use your pinky & heel of your hand, give the file a few degrees rotation at each chain tooth, this spreads usage around the file. This gives the file teeth time to clean out. This is not an extra operation, you just work it in to your M.O. Like walking and chewing gum at the same time. Sometimes run your glove backwards across the file to clear the chips from the file teeth. I'm always surprised how much simply rotating the file a little makes a difference. Almost like the file is sharpening itself - try it!
I try to use between 2 and 4 strokes per chain tooth. Each unnecessary stroke is less chain life.
   / a sharp chain! #36
I just sharpen mine with a file by hand and do it with the chain on the saw. I can sharpen the chain about as fast as swapping out chains.
I have never used a real chain grinder. I tried one of those that are sort of like a Dremmel tool, its on a shelf somewhere around the shop. I do have one of those Oregon hand jigs, also on the shelf somewhere. I also just use the round files on the cutters and "eyeball" it. The commercial round ground chisel chain is my favorite. I will touch-up a chain three times in the field, on the fourth I remove the chain after sharpening and rotate to one of my other two chains that I buy for each dive cog. When three chains are worn out, the cog is about due for replacement too and I would never put a new chain on a worn cog.
I had a set of three chains sharpened "professionally" once because one of the relatively new chains had two broken cutters the shop was replacing. The result was a nice sharp chain, but the cutters were half ground away!
prs
   / a sharp chain! #37
I have never replaced a cog. Certainly they cant last forever, butttttttt,,,,,,,, ???? That sounds like an expensive way to save money.
   / a sharp chain! #38
Sodo, a worn cog will be out of pitch with a new chain and thus cause chain stretch. One might end-up needing to remove a link in order to get the chain taught. I use open spur cogs that are part and parcel of the clutch clamshell; maybe that choice makes some difference, I dunno.
prs
   / a sharp chain! #39
PRS what you write makes sense,,,,, in theory. I understand what you are saying if it was machinery, or a motorcycle, bicycle.
Still,,,,, in practice, I have never changed a cog on my chainsaws, and never had trouble tightening a chain, never noticed chain stretch. As far as I can tell ,,,,, and running on old cogs, my chains have are worn out when there's no longer enough "tooth" to be sharpened, not stretch.
Maybe I'm not paying attention. I dont cut wood for a living probably bought about 10 chains (&zero cogs) in my lifetime. And I run a chain to the bitter end so maybe the normal guy woulda bought more chains.
   / a sharp chain! #40
I have used my new Timberline Sharpener a few times now. I've tried quite a few different jigs, clamps, and files, but this one is certainly the method I'll stick with. I really like how exact it is, and how easy it is to make every tooth an identical length.
I just wish for something so "exact", they had a more precise way to file the depth gauges.
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2013 Ford F-150...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A57453)
2014 Ford F-150...
2008 Isuzu NPR-HD Landscape Dump Truck (A56858)
2008 Isuzu NPR-HD...
2014 DRAGON 130 BBL VACUUM TRAILER (A58214)
2014 DRAGON 130...
