A qustion for CK20 owners
   / A qustion for CK20 owners #11
Is that a piece of concrete pipe? If yes how big is it?
KC
Yeah, the contractor decided to put the drilled well in the middle of my driveway so I decided to bury it. The concrete casing (well tile) is 36" in diameter, 42" tall and 3" thick with a dual liftout cover. I cut 6" off of the bottom since I hit some large rocks just 46" down and wanted the cover to be about 6" below final grade. I then drilled a hole in the side and ran a 4" PVC pipe out to the driveway edge to drain any water that may buildup in the well tile. Here is my thread of the project. :D
As a fellow New-Hampshire-Ite, I couldn't help but notice the rocks that were hit during trenching, not easy stuff to dig through.
Must say though, the rocks are mighty small compared to the stuff I hit, I literally can not go down 6 inches without hitting something at least the size of a 5 gallon pail. 3 foot down and I'm talking 55 gallon drum sized rocks
Yeah, luckily the trench was across the driveway which is mostly fill. If it had gone through untouched ground, I would have been digging for days. :D
Impressive, around 1100 lbs of lift. Great photos, thanks for posting!!
KC
   / A qustion for CK20 owners #13
KC
Yeah, with a little math I figured it weighed 1110lbs. Here is a pdf with the dimensions. It was also hanging at the center of the loader bucket so the weight was quite a ways from the pins they measure the lift capacity at.
49875.92 in3 Outer diameter volume
36643.54 in3 Inner diameter volume
Outer cylinder volume minus the inner cylinder volume = total cylinder volume
49875.92 in3 - 36643.54 in3 = 13232.38 in3 Concrete
13232.38 in3 / 1728 = 7.66 ft3
7.66 ft3 * 145lb/cu.ft = 1110.7lbs of concrete
It may be listed at 1074lbs of lift at the pins but I know it lifts more, oh and this is with a cracked loader too! Good thing I have that reinforcement plate. :D
   / A qustion for CK20 owners #14
Oh my God... You actually used that flimsy weak loader.... What were you thinking???
Oh right, ... that it is a fine piece of equipment, and that it can do a TON of work..
PS: I own a strengthened loader and I approve this message!
Sheets of Tin (A57149)
Sedan (A59231)
Sedan (A59231)
Stanley Tool Box with Tool (A57454)
Stanley Tool Box...
2020 CASE SV280B SKID STEER (A52709)
2020 CASE SV280B...
Flow Tech F15 Ball Valve With Gaskets SOLD 35x Times Money (A59213)
Flow Tech F15 Ball...
Unused 84" Bucket Attachment (A55272)
Unused 84" Bucket...
