A quieter PT422
   / A quieter PT422 #11
Good deal. Does it still look like the first pic you posted? I'll bet that mig welder is NICE! I am still sticking and beating flux.
   / A quieter PT422 #12
That looks like a great modification pardon my ignorance but what is a MIG welder?
   / A quieter PT422
I don't know what MIG means, but it's a welder that feeds the wire directly to the weld and doesn't use flux, but uses a mixture of argon and carbon dioxide to keep the weld clean. No slag. Nice weld even if the welder is less than skilled (like me). Yes, it looks like it did with the hose clamp, only no clamp.
Phil
   / A quieter PT422 #14
<font color="red"> what MIG means </font>
metal inert gas
   / A quieter PT422 #15
Thanks for the update!...I'll be ordering mine soon since spring is right around the corner(I hoipe!) and windows will be open more often.
   / A quieter PT422 #16
I looked at my 422 exhaust last nite and the pipe out doesn't look wider that 2" more like 1 1/2" how do you get the 3" to fit? Do you use other fittings as well?
   / A quieter PT422
The OD of the pipe that exits the bottom of the PT muffler on MINE is 1 and 1/4". The Supertrap comes with that ID on the inlet and is the one I used (other IDs are available). The outside diameter of the whole Supertrap is 3". There is a 5" model that won't fit on a PT without some major modification (more than I'd like to do). I can take some more photos if it would help.
Phil
   / A quieter PT422 #19
Phils, can I borrow yours?.. they are backorderd until 3/24/05.. I could be deaf by then. Oh I just remembered you welded yours on.. never mind.
   / A quieter PT422 #20
Was wondering if any of you diesel guys have tried any different mufflers than the stock PT one. I sure would like to quiet down the 2cyl on the 1430.
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A57024)
2014 Doyle Dry...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
(2) 10" X 12# X 70.5" (1) 10" X 12# X 104" I BEAM (A57192)
(2) 10" X 12# X...
2021 GMC SIERRA CREW CAB TRUCK (A57192)
2021 GMC SIERRA...
2016 STOUGHTON 53FT DRY VAN (A57880)
2016 STOUGHTON...
2018 Autocar ACX Xpeditor T/A EZ-Pack Hercules 40 Yard Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
