A quieter PT422
   / A quieter PT422 #1
Phils
Platinum Member
Cherokee, CA
PT-422
I had discussed this in the "customization" forum, and since it's done and working I thought it appropiate to post the photo here.
I installed a Supertrap muffler on my 422 a week ago. It provided a significant decrease in noise. The machine is now only as loud as a normal lawn tractor (which is about half as noisy as it was). I initially installed it according to the directions, with a hose clamp. As I expected, after about a half hour of stump grinding it fell off, with the sudden increase in noise making it obvious what had happened. I reattached it temporarily with a couple of screws and will weld it on next chance I have.
Total price for it was $90, which included the muffler, resonator and three 3-paks of discs. The application says to use one disc for each 3HP, so I should have needed 7 but since you buy them in paks of 3, I put all nine on. I've noticed no reduction in power, only less noise.
Phil
   / A quieter PT422 #2
Thanks for the pic and info...looks like a muffler on a muffler? This won't have any negative effect on the engine I /forums/images/graemlins/confused.gif hope!
   / A quieter PT422
I can't imagine anything bad it could do, as there's no perceptible back pressure with those 9 plates installed.
</font><font color="blue" class="small">( This won't have any negative effect on the engine I hope! )</font>
   / A quieter PT422 #6
</font><font color="blueclass=small">( The application says to use one disc for each 3HP, so I should have needed 7 but since you buy them in paks of 3, I put all nine on. I've noticed no reduction in power, only less noise.
Phil )</font>
Hmmmm, the application I read on the Web said to use 1 disc per every 7HP, and you are using 9?
   / A quieter PT422
</font><font color="blue" class="small">( Hmmmm, the application I read on the Web said to use 1 disc per every 7HP, and you are using 9? )</font>
<font color="black"> It's one disc/7hp for the 5", and one disc/3hp for the 3". The 5" wouldn't fit on my PT without some major muffler mods. I wanted something simple.</font>
   / A quieter PT422 #8
How did you fit it on with the square pipe coming out of the muffler?
   / A quieter PT422
Mine has a round pipe coming out of the muffler. I figured there have been enough different mufflers that I should show a photo of the one I have, but I didn't realize that ones like mine had a square final exit pipe too. Guess that's one of the fun things about the PT..... the ol' box o' chocolates from Forrest Gump.
Phil
   / A quieter PT422
Just an update. Finally tried out my new MIG welder this weekend and attached the SuperTrap permanently to the PT exhaust. When reassembling the SuperTrap I used the recommended discs (seven instead of the previously installed nine) and it quieted the little machine even more! No problem with power that I could notice.
Phil
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
Polaris ATV (A50324)
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
50ft Fuel Line (A51573)
50ft Fuel Line...
John Deere 5400 Tractor with Loader (A51573)
John Deere 5400...
