A PTO shaft hanger for my rotary cutter
   / A PTO shaft hanger for my rotary cutter #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
I decided it was time to build a PTO shaft hanger for my rotary cutter today.
I looked around for materiel's, and didn't find much.:mad: I did come up with a screw in hanger of abut the right size, and a piece of 1/4 inch all thread about 2 inches long..
I cut the hanger on an angle and likewise one end of the all thread to more or less match the angle of one of the rotary cutters supports.IMG_20140512_142501_263.jpg
I drilled the support, to receive the all-thread.IMG_20140512_135958_480.jpg
Next I clamped down the two pieces of metal to get ready to TIG weld them together. How do you like my Rube Goldberg Clamping arrangement? Pretty ingenious huh?:)
Here it is after being TIGed. It is lousy cadmium plated hardware.. I filed some of it off, but you don't get rid of all of the contamination., but it turned out OK.IMG_20140512_150217_505.jpgIMG_20140512_150450_072.jpg
Here it is installed on the support of the cutter with a spot of black paint.IMG_20140512_151355_453.jpg and here is the PTO shaft resting on it.IMG_20140512_151419_169.jpg
It is probably not the sturdiest hanger ever built but if it breaks, I will just drill a larger hole and make something bigger.:) It is a 0$ project, except for a few cents of argon for the welder and some scrap.
   / A PTO shaft hanger for my rotary cutter #2
Looks good to me.:thumbsup:
   / A PTO shaft hanger for my rotary cutter #4
Thanks TripleR, yours was my inspiration. :thumbsup:
Would one of you be interested in making one for my tiller? I will pay you for time, materials, and shipping.
Thanks,
Jeff
   / A PTO shaft hanger for my rotary cutter #5
Mine came that way; fabrication is something I have to leave to my brother or sons, wish I could help.
   / A PTO shaft hanger for my rotary cutter #6
It appears that you can keep your stuff in side, and that is great,
but I have always found it best to spate the PTO shafts and keep there separate in storage and then clean and lubricate and slip them back together when need and used, it does not take much to rust them to the point where one can not move them. having the hook to hold the machine part up off the dirt is good tho,
a chunk of wire works (not very pretty) but will work to hold the PTO shaft up if needed. just remove before using so it can not get tangled up,
Thanks,
Jeff
It might be kind of hard with you tiller in NC and me in MO. to get things right.. send some pictures with how the PTO shaft would be hung in mind. remember the shaft must go up and down with the 3PT. and the hanger cannot interfere with this range of motion. Send me some pix, and we will see.
And lemme tell ya, if anything can get tangled up in a PTO shaft, it WILL!:shocked:
   / A PTO shaft hanger for my rotary cutter #9
Here are mine:
All it takes is lack of imagination and fabrication skills=no problem for me. :eek:
Seriously though...your hanger looks great and now I'm determined to finally do something like that. I've used the bungees long enough and lost a few when I forget to store them after attaching the mower. It's only been 10+ years...no use rushing into this stuff. :)
Here are mine:
View attachment 374892 View attachment 374893
Hey, whatever works.:) You must have some sort of quick hitch, I see you have some bent washers for the ends of your 3pt pins. I made up some of those when I was using the Carters version of a Quick Hitch.
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2015 INTERNATIONAL...
JOHN DEERE 5083EN LOT NUMBER 136 (A53084)
JOHN DEERE 5083EN...
SHOP MADE MANIFOLD TRAILER (A52472)
SHOP MADE MANIFOLD...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
6x14 Double Axle Bumper Pull Trailer (A51572)
6x14 Double Axle...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
