Loader A little trouble with my 5035
   / A little trouble with my 5035 #11
This may or may not be your problem, but many loader valves have a regen cycle in the dump circuit. As you push the valve handle outward to dump, there is a spot where the valve will do nothing, push it a little further and it dumps again, but a little faster, as it has gone into regen mode. By design, there is a little spot on the spool where you get a hesitation. Below is a copy/paste from KennyD from another forum, he explains it well. I find it to be most noticeable when the pump is putting out the lowest flow, at idle or just above. If this is your issue, then you do not have a problem actually. Quote follows:
Regen is a "feature" of most modern FEL (Front End Loader) valves, it's on the Dump (joystick far right) circuit, and is also referred to as "Fast Dump". The reason it is nice to have is that without it, the weight of a filled bucket can actually "pull" the bucket down faster then the fluid can enter the other side of the cylinder, this will create a air pocket and give the bucket a "floppy" feeling until the joystick is held in the dump mode a few seconds to refill the cylinder pushing the air past the seals. So we add "regen" or "regenerative" function to the valve.
Regen solves this problem by actually filling both sides of the cylinder at the same time with hydraulic fluid. But how will that work you might ask? Well, because there is more volume on the side of the cylinder that extends it since the rod is taking up space in the other side, it "overpowers" the rod side and lets the cylinder extend-thereby dumping the bucket. So since now both sides of the cylinder are "pressurized", the air pocket can not develop, eliminating the "floppy" bucket syndrome. One other added bonus is that the bucket actually dumps faster due to the higher flow rate required to do all this, that's why it's referred to as "fast dump" sometimes.
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
2022 Adams CLC-1013 Conveyor - New (A55314)
2022 Adams...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2006 MAC TRAILER MANUFACTURING (A55788)
2006 MAC TRAILER...
2013 TAKEUCHI TB235 EXCAVATOR (A52707)
2013 TAKEUCHI...
2020 Kia Soul SUV (A55973)
2020 Kia Soul SUV...
