A little help with MF 1523 Hydraulic filter
   / A little help with MF 1523 Hydraulic filter #1
mmurd
Massey Ferguson 1523
It is probably somewhere in the forums .
I am looking for a Hydraulic filter match for my 1523 Massey Ferguson . After getting sticker shock on the OEM
there has to be a better deal .
Thanks for any advise .
   / A little help with MF 1523 Hydraulic filter #2
Hydraulic filters are expensive. They're much larger than engine oil filters and often have higher spec filter material. And the market for them is smaller.
Just because a filter has the same external size and threads doens't mean that the filter material is the same quality. Or that the relief is the same pressure, or that it
has or doesn't have the same anti drainback as the OEM filter. It's often impossible to get those values for both OEM and aftermarket filters to allow a true comparison.
Certainly when in warranty I use the OEM filters. For most filters on most vehicles I use OEM after warranty too. It's like using good oil.
HST and hydraulic innards on a tractor can be expensive to replace.
Thanks for your input .After reflection I will be going with the OEM.
Its one of the what could possibly go wrong issues .
   / A little help with MF 1523 Hydraulic filter #4
I just purchased a strainer for my 2615 from the dealer for 12.00. My local auto store had cross referenced it and was quoting $60. I looked at it and the dealer calls it a strainer which is what it looks like, just metal mesh but getting to it is a real pain. It's up under the gearbox.
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
1995 Rinker Captiva 190 (A52748)
1995 Rinker...
New Long Forks (A53002)
New Long Forks...
