A little advice from the experts please.
   / A little advice from the experts please. #1
90acres
SE Georgia
NH TC55DA SSS
I have 90 acres in planted pines in SE GA. I have built a road (1/2 mile long) using borrowed/rented equipment and plan to buy a tractor to maintain the road, clear some of the 5 year old planted pines - to plant 1 acre food plots, and mow between the 10' rows. Basically, I want to create a place to hunt for years to come and need a good tractor. I am looking in the 45-55 HP range with loader, box blade, disk, and bush hog. What would you buy? Thanks for your opinion.
Additionally, the land is flat, but has some swampy areas (appox. 10 acres). I think Ag tires are a must. I have looked at JD, NH, Kioti, Kubota and will most likely choose one of the above unless this web site can convince me to buy something else. Thanks again for any help you might give me.
   / A little advice from the experts please. #3
You can't go wrong with any of the 4 choices. Test drive and buy the tractor you can afford. See which one fits you the best. My tractor was in my price range and it handled great. Most important is what you like. The dealer can be a part of your decision, but I really don't think with any of the 4 tractors that you will spend much time going back to the dealer for repairs. Good luck!!
Thanks. I just visited the Kioti dealer today and found both the 45 and 55 to be very solid looking machines. They were quiet as a mouse, easy to operate, and priced to sell. I was impressed even though this was my first look at Kioti. Had to drive 70 miles, but worth it in my opinion. I would like to get everything I need to last for a very long time, so I am willing to spend up to 30K for the tractor and all of the implements.
   / A little advice from the experts please. #5
Those are all good choices, however if you have an open mind and like to shop.... you might want to take a look at a Branson 4720 , since their corp headqtrs are in Georgia.
Oops ...you said advice from experts....well scratch what I said.
sassafraspete
That's what I am looking for. Advice! Thanks. You know those titles-what do I name this thing? Why Branson?
   / A little advice from the experts please. #7
yeah... I know... I prefer to think of it as a kukje....since that is the company in S Korea that makes them. It is worth a look though.... especially for what your are using them for. With that much acreage, If you were into heavy farming...I'd have to say look at the bigger utility tractors like those jolly green ones. However, if you are doing food plots and bushhoging and a little driveway maintenance... the kukje..er I mean branson would be worth a look. You might find enough of a price advantage to be able to pay for some of your implements.
Good luck with your hunting grounds...and good deer hunting.
sassafraspete
Thanks again. My food plots will only be 1 acre in size and I plan to have about 10 of them spread out all over the property. I have to let the pines grow to earn a profit from them when I thin them in ten years, so I won't be using the tractor for heavy farming, just to maintain the food plots, mow a few rows and keep the road maintained.
   / A little advice from the experts please. #9
Welcome aboard Sailor! I'm no expert and a rookie to boot, but I'm an ex Jar-Head and I always did like you Squids /forums/images/graemlins/grin.gif So here's my two cents worth.
I just bought a JD 5205 MFWD and FEL. 56HP gross, 50 PTO. I think it is a lot of tractor for the money and sounds like it would do what you need it to do and then some. It is a utility tractor. Most folks here have compact utilities and have done some incredible work with them. I also own a small Kubota B8200D I bought used which has served me well for keeping up the driveway.
The 5205 fit me well and the dealer is close by and took the time to actually listen. There are a lot of excellent tractors out there. Decide what is the most important features to you and compare apples to apples. How important do you consider your relationship with your dealer? Lots of things to think about.
These tractor owners here have been around a while and know a lot more than I do. Plus there is a ton of information in the various forums.
Hope this was helpful. Happy shopping!
Hu Ya Sir. Thanks for the infomation.
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
2018 JLG 3246ES 32FT. Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2008 Ford Escape Hybrid SUV (A51694)
2008 Ford Escape...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
