Rear Blade A hydraulic angling rear blade??
   / A hydraulic angling rear blade?? #1
ledebuhr1
Is there a company that makes a rear 3-pt blade that is hydraulic angling?? The only ones I can find are for larger tractors. I am looking at getting a Kubota L3430, which is 35hp. I would need a 6ft Cat 1 blade(i think).
Is there any engineering reason that rear blades with hydraulic angling cant be made for smaller trators??
Wouldent they be just like the bigger ones, just scaled down?
   / A hydraulic angling rear blade?? #2
I have a Land Pride RB3572 on my 2910 that has hydraulic offset. Here is a link to a thread that has a picture of mine and Boondox’s rear blade. Click Here
   / A hydraulic angling rear blade?? #3
I have to go thru this little dance with my
(non-offsetable) backblade: When I change the angle that throws the snow off to the side, the blade doesn't sit flat on the pavement afterward so the tilt link needs to be adjusted as well. This apparently is because the pivot axis is not exactly vertical and its pretty sensitive because when I put on the implement, I try to visually level it. I haven't tried a level yet.
Anyway, with your hydraulically offsetable arrangement, if you were unable to get the offset pivot axis exactly vertical for one reason or another, it seems that the blade wouldn't sit flat after changing the offset. Ronjhall has a hydraulic tilt to deal with it (he filled out his profile...) It would be unfortunate to have the hydraulic offset but still have to get down off the tractor to flatten the blade.
Thanks for your help. That land pride looks like what i want.
So it can adjust tilt and angle? how much Hp do you need to pull it??
Oh, and how much does it cost?
   / A hydraulic angling rear blade?? #6
I also have a Landpride RB3572, I pull it with a 36 hp tractor. You can adjust the tilt, the offset, and the angle. A new one should run some where around $900.
Thanks for your help, How easy, or hard, is it to adjust the angle or offset while your driving the tractor?? or is this something your do while not moving??
   / A hydraulic angling rear blade?? #9
I have been happy with bison.
This bison is to heavy for your tractor. It comes ready to go for hydraulic cylinders, just remove the pins and add the cylinders and plumbing.
I am not sure what they offer in the shorter lengths.
Fred
2003 Big Tex 10PI...
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
Kubota SVL 97-2 (A53317)
Kubota SVL 97-2...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
(APPROX. 26) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 26) 4' X...
