A hotshotters Cummins stats
   / A hotshotters Cummins stats #1
dodge man
Super Star Member
West central Illinois
JD 2025R
I am also a member of a Cummins forum and there is a poster that is a hotshotter. His truck is a 2007 dually with a 5.9 Cummins in it. He just recently had to put in a rebuilt engine at little over 900,0000 miles. He was on his third set of injectors, he got something like 406,000 miles out of his first set. He is on his third transmission. What finally failed was an injector over fueled and fried one of his cylinders. I'm sure the engine could have been rebuilt but it was quicker to put in a reman. In the past he posted all the maintance work he has done to the truck. He was over a 120,000 miles before he had to fix anything, and that was a pinion seal.
Some truly amazing stats. Based on his engine hours, he has an average speed of 53 mile per hour. He has also averaged a little over 15 mpg out of this truck, of which about half were hauling RV's for delivery.
Here are the stats for his first engine.
Got the truck back.
Got the hours from the computer.
Hours on the old engine.. 17,002
Miles 904,313
Idle Hours 995.267
Idle Gallons used 974.21
Total fuel burned by truck 60,118.04 gallons.
   / A hotshotters Cummins stats #2
I'm no expert, but it seems odd that over-fueling a cylinder would fry it. I don't know diesels well, but in a gas I would expect the opposite effect. Maybe a more knowledgeable person could explain this?
   / A hotshotters Cummins stats #3
I agree impressive but the cummins is a very impressive engine, always has been. I use them in my power units anytime I can. The best I have heard out of the only comparable engine IMHO is about 700k with the 7.3L IH. Sorry but the new stuff does not even come close to the Dodge/Cummins. The jury is still our on the 6.7 Ford engine, 250-300k is the most I have seen so far. If I was shopping I would take a long hard look at the Dodge along with the Ford. CJ
   / A hotshotters Cummins stats #4
Dodge man,
Thanks for posting this info, am awaiting numbers on MPG with the SCR Cummins.
Next truck will be a Dmax Sierra or a Ram Cummins,
   / A hotshotters Cummins stats #5
You over fuel a diesel 1 of 3 things WILL happen. The cylinder will overheat, hydrolock or wash out. CJ
   / A hotshotters Cummins stats #6
We had one with even better service history than that. This '03 3500 DRW 2wd went to ~840,000 before an injector washed a cylinder. The engine was otherwise unhurt, but he decided it was time and sold the truck in need of injectors. It had filled the crankcase with fuel and was spewing out the vent. With the oil level corrected and that injector shut off it ran great, other than the miss.
Had one set of replacement injectors, the front end if the engine resealed, one transmission rebuilt, one replaced, a set of rear axle seals, seat padding redone, a couple of minor electrical gremlins and that's it! He bought a low mileage '04 to replace it.
All this on an engine that is not built to the same standards of the old mechanical Cummins engines. The newer CR Cummins have lighter head and block castings. That being said they make ANY Powerstroke or Duramax look like a toy.
I've heard of an original internal hotshot 5.9 truck that had 1.7 million on it and still trucking. They are built tough as nails, with real solid Indiana engineering from high quality parts.
   / A hotshotters Cummins stats #7
I have personally seen a million mile Cummins, Duramax, and 6.0 Ford. I have also seen a million mile 1/2 ton Chevy with a 350 that was on its 3rd motor.
What amazed me more than the miles was the shape all the trucks were in. To not get into a wreck at a million miles is the amazing part.
Chris
You can't think of diesels in terms of a gas engine, totally different. In this case CJONE has the things that happen when a diesel over fuels. In this case, it sounds like the body of the injector cracked badly and it over fueled that cylinder and caused a major problem in a very short amount of time. He had major blowby after he replaced that one injector.
In this guys log of repairs, at some point he was hit by a van and replaced a door and all or part of the bed of the truck.
   / A hotshotters Cummins stats #9
Pretty impressive he got 120k without having to fix anything.
I dont know it the 2007's used different axles or u-joints, but I had to replace a rear DS joint @ 69k, and then front axle joints @ 75k. But mine is an 05.
Mom's 05/hemi also need a rear shaft joint @ 45k, and then wheel bearings and joints on the front @ 80k.
Still a great truck otherwise. And I like my 5.9:thumbsup:
   / A hotshotters Cummins stats #10
What surprises me when I hear these types of numbers, is that they are not rusted out. Seems from the midwest east, rust is harder on vehicles that anything else(if generally kept in tune, oil change etc).
Chris
2025 AGT YSRT14 (A50123)
2025 AGT YSRT14...
2002 Mack CX613 Cab & Chassis (A53117)
2002 Mack CX613...
2025 K1220 UNUSED Single Garage Metal Shed (A53117)
2025 K1220 UNUSED...
Sterling 9500 (A53473)
Gravely 160Z Zero Turn Mower (A53117)
Gravely 160Z Zero...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
