A Harrowing Experience......
/ A Harrowing Experience...... #1
Cityboyfarmer
Macon, Ga.
Kubota B8200D; JD 5205 MFWD w/522 Loader
My first ever harrowing project. This is my experimental pasture. I planted common bermuda. I spread 400# of lime, 200# of 10-10-10 and meant to sow 25# of bermuda seed, but wound up using the whole 50# bag on about a half acre field. /forums/images/graemlins/blush.gif . I've got to get a better spreader.
How do you guys spread bermuda seed? This stuff is expensive and I don't want to use anymore than is required. I'll be seeding 6 acres in the not-too-distant future and I want to get it right.
Here's a few photo's:
Another:
Shot #3
/ A Harrowing Experience...... #4
Nice looking rig.
In my farmer days, we'd disk maybe twice, wait for a good rain to settle the ground, let it dry, then disk it again. Then ready to plant.
Best wishes,
ron
Didn't get any photos of the actual seeding, but what I did was smooth the field with my box blade after harrowing in the fertilizer and lime. Then I seeded the field and covered the seed by dragging an old gate with a log chained to the top.
Here are some photos of the result a week later after 3 gully-washing, frog-choking thunder storms:
Another angle:
Last one for now. Hopefully in a couple of weeks I'll be posting photos of lush green bermuda.
/ A Harrowing Experience...... #8
Thats gonna look real nice after that Bermuda starts growing!
/ A Harrowing Experience...... #9
That field looks like it worked up real good and you did a good job.
Will the lush green in two weeks be just on the ½ acre?
Or did you find a way to seed the other acres, per your first post in the thread? Or maybe this field you are showing is just the ½ acre.
I remember my father broadcast seeding 5 acres into oats with alfalfa and some very expensive ladino clover. The little bag of ladino was gone from the small-seed 'bin' after about 20 feet. Needless to say, it wasn't set right and my father was none too happy (that was about 1951 /forums/images/graemlins/tongue.gif )
Thanks for the pics.
/ A Harrowing Experience...... #10
Lovely photo's.
oooodeeeee that's a nice big tractor. I want one too.
And you are correct sir, some drizzly rain would be nice instead of gully washers. We are a bit on the dry side here at the moment. It hasn't rained at the ponderosa in quite a while, since before July 19 for sure, I have stuff piled up for burning since at least then.
Your place is looking nice. Good luck with your grass.
I however, am firmly resolved that those who fertilize and water get exactly what they deserve, cutting the grass twice a week. 'Cause I can't be jealous without showing it.
Have you ever thought about wildflower mix?
Honestly I do like the smell of cut grass, more so though than the missus likes to cut it. Ah ha. My dogs love to run and jump in the wildflowers and my only purpose in life is to keep them and the missus happy.
You are a lucky man indeed with that much land to oversee.
All the best,
less fortunate Martin
/ A Harrowing Experience...... #11
You might learn from some of my former mistakes. On a lawn we were re-doing years ago (it had a lot of slope), we worked and smoothed and planted it. Several heavy rains later, there were some foot wide & deep gulley's in a few spots.
So I dilligently filled them in and replanted, only to have it wash out again. Finally, I got a little smarter: I left the gulley's just like they were until the rest of the yard was lush and established. Then I filled the gullies A LITTLE HIGHER than the surrounding grass and reseeded. I also packed it down really good. Problem solved. The former gullies became lush and green.
Of course, it takes having some available dirt to utilize later. Have fun. Wish I had a disk and a place to use it..........
Ron
/ A Harrowing Experience...... #12
I mixed my Bermuda seed with couple bags of play-sand then dumped it into my 3pt spreader, it also works with clover for over seeding.
Beenthere,
I have not planted the other 6 acres yet. They are currently being cleaned up from being clear-cut logged in May. I am documenting that project in This Thread.
It will probably be fall before those acres are seeded and I will most likely plant winter rye-grass and then over-seed with common bermuda in the late spring.
</font><font color="blue" class="small">( I mixed my Bermuda seed with couple bags of play-sand then dumped it into my 3pt spreader, it also works with clover for over seeding. )</font>
dlgmt,
What is your sand-to-seed ratio? How did you get the seed and sand mixed evenly?
/ A Harrowing Experience...... #15
CBF,
Pretty land you have there. That bermuda is going to be as thick as hair on a dog's back!
I like bermuda because of the hot dry summers we have. It grows very slowly, and goes a long time between cuttings. If it weren't for the weeds and rough grasses, it would never need cutting.
Well, its a couple of weeks later and there's some green stuff growing! /forums/images/graemlins/laugh.gif
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
6x12 Leonard Utility Trailer (A65579)
6x12 Leonard...
2003 International 4300 Flatbed Dump 571559 (A62613)
2003 International...
Cattle Feeder (A65640)
2017 Subaru Forrester (A62613)
2017 Subaru...
