A HARD PTO PROBLEM TO SOLVE
   / A HARD PTO PROBLEM TO SOLVE #51
I would assume if he swapped gear boxes, he swapped complete units, including blades.
   / A HARD PTO PROBLEM TO SOLVE #52
I don't have a way to measure my pto speed but it sure seems to speed up and slow down with the speed of the engine. I know 540 rpm is standard but at what engine speed?
Pro rpm is ratio locked to engine rpm. Most tractor tach have a mark where you hit 540 on the pto
   / A HARD PTO PROBLEM TO SOLVE #53
I'm making no assumptions. Just going by the ops statements, including the one where the mower worked fine on another tractor. ;)
   / A HARD PTO PROBLEM TO SOLVE #54
Thanks Soundguy,
I've been trying to figure out why that mark was on the tach.
   / A HARD PTO PROBLEM TO SOLVE #55
Without seeing a picture from behind, like with the NH tractor, I'm only guessing the wheel spacing on the other tractor would be wider, and blades making contact at a different angle. More than likely blades hitting the downed grass from the side, rather than straight forward, towards the already downed grass, also leaning forward.
Even with a single deck mower that is wider than the wheel tracks on the tractor, your going to leave a streak on the side the blade is coming forward if it happens to be inline with the tractor wheel in tall weeds/grass. However, on the next round, depending on how far you stay over on the already cut portion, the side with the blade cutting towards the back, may cut most of that streak out.
2019 BOBCAT T590 SKID STEER (A52709)
2019 BOBCAT T590...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
2014 International Derrick Digger Truck (A55973)
2014 International...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
2013 Ford Taurus (A56859)
2013 Ford Taurus...
2012 MACK GU713 (A58214)
2012 MACK GU713...
