A good old fashion blizzard
   / A good old fashion blizzard #11
i have issues when not dry outside with fogging if the air cond is not also on. problem is that the air is much less warm with it on vs off. called my dealer - they claim that many have complained about this issue. only way to defog is to turn on the air cond and loose a good portion of the heat. crazy design flaw.
i would post picts with my blower but we only have 4inches on the ground!
   / A good old fashion blizzard #12
I think a regular fan mounted on the top inside corner of the windshield would be a better solution than running the airconditioner in winter.
jmf
   / A good old fashion blizzard #13
will consider that
running air con is actually good for the air con system - needs to stay lubed.
i just turn it on for 5-10 minutes when needed
   / A good old fashion blizzard #14
Another thing you might want to check is the heating core. Moisture could be seeping in through the one of the hot water connections. Not only a visual problem, breathing antifreeze is not good for your health.
jmf
   / A good old fashion blizzard #15
My rear window fogs up occassionally. Not enough that I cannot still see out of it. The side windows too but that is less frequent and usually when there is a passenger. I only run the blower on low and for the most part it does well.
FWIW, I've run numerous AG tractors and rubber-tired end loaders. They all had the same problem to some degree.
dsb
   / A good old fashion blizzard #16
I have seen this in two vehicles I owned. The first one bugged me for years and I never suspected the heating system until it got so bad I could smell the antifreeze. It just takes a very small leak to fog up a windshield. This is why it usually cannot be seen and repaired. If there is someway to test the droplets on the windshield, I would bet you'll find a trace of antifreeze.
jmf
   / A good old fashion blizzard #17
   / A good old fashion blizzard #18
We just got the tail end of that storm up here in Canada. Only 6" of snow but it was -30 C and blowing hard.
The wind threw the snow right back at the snow blower. Then it froze to the windshield. It was a long frustrating night, cleaning the windows every 10 minutes.
I'm having the same problems as everyone else it seems. The A/C has to run to prevent fog on the glass but then you don't get as much heat. My glass not only fogged up but then iced up because it was so cold in the cab.
I bought an auxilary fan and 12 v heater and they made a difference. I hung the heater up by the windshied wipers to melt off the ice that collected on them.
I'm thinking of installing an extra heating system in the heat liner to blow on the front and rear glass. Hope they get this problem fixed by the next model series.
Great to see so many tc in action.
   / A good old fashion blizzard #19
I have the same issue with windows fogging up in my Toolcats. The "solution" I use is to turn up the blower a notch, and crack the passenger side window. As long as the snow is not blowing in the cracked window, the windows stay perfectly clear.
   / A good old fashion blizzard #20
Next time you see a build up on the inside see if it feels slippery.
jmf
2006 MACK CXN613 FLATTOP SLEEPER (A55745)
2006 MACK CXN613...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A53843)
2013 XLR...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2021 Ford F-150...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
Decorative Horse Statue (A55758)
Decorative Horse...
