A good friend just picked up a low hrs JD 5403, and it broke. "PTO"
   / A good friend just picked up a low hrs JD 5403, and it broke. "PTO" #1
broken111
Kiamichi, Ok
1965 Ford 3000
The plate on top of the transmission where the PTO lever attaches broke off. It is a threaded hole where only one bolt
holds the PTO lever in place. Looks like a very poor design to me.
I figured to get the days work done, we could position the PTO lever by hand to engage the PTO, but no such luck.
Why could we not get the PTO to engage manualy?
Any ideas on a fix?
Thank you
   / A good friend just picked up a low hrs JD 5403, and it broke. "PTO" #2
Will need some pictures to get any ideas.
   / A good friend just picked up a low hrs JD 5403, and it broke. "PTO" #3
It's a shoulder bolt. Extract the broken piece and replace the bolt. If the bolt was loose, it would bind, breaking the bolt. Make sure the adjustment is properly done.
The bolt did not break, the hole the bolt goes into broke. It is part of the transmission, the upper case cover. No pics, sorry
   / A good friend just picked up a low hrs JD 5403, and it broke. "PTO" #5
Check it out with your Deere dealer. It should not have just broken with normal use, and maybe some underlying cause is the culprit.
Not possible to get some pictures and post them? A neighbor, some friend, some kid?
I'll try tomorrow
   / A good friend just picked up a low hrs JD 5403, and it broke. "PTO" #7
Which bolt broke?
   / A good friend just picked up a low hrs JD 5403, and it broke. "PTO" #9
Might be time to try JB weld. I don't really like the stuff but it beats replacing an entire case. That's a whole lot of labour whether you pay for it or do it yourself.
   / A good friend just picked up a low hrs JD 5403, and it broke. "PTO" #10
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A54607)
2007 PETERBILT 379...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
2013 BIG TEX BIG TEX (A53843)
2013 BIG TEX BIG...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
1981 LUFKIN 41 FLATBED (A53843)
1981 LUFKIN 41...
2013 Great Dane 53ft T/A Reefer Trailer (A51694)
2013 Great Dane...
