A follow up to my thread about band saw mill pad.
   / A follow up to my thread about band saw mill pad. #1
Gitche Gumee Kid
NW WI
IH 284
   / A follow up to my thread about band saw mill pad. #2
The top of the bed of my Woodmizer is right at 26" off the slab I have it on. That seems to be a good working height for me.
I also have the mill tilted about 10 degrees back into my working side....that helps hold a log up against the dogs without having to bother clamping it if I roll it around to the 'sweet spot'. Many logs are not perfectly round, and by turning them, you find the spot where it sits up against the dogs without moving...aka the 'sweet spot'. This works well on a Woodmizer because of the cantilever design of the head.....might NOT work on a mill that uses an inside and outside rail to ride on....dunno...
I also hold that first slab cut off the log on the deck, roll the log 90 degrees flat to the dogs, then shove the slab under the outer edge of the log and that will often hold the log tight against the dog, again saving me having to fool with the clamp.
   / A follow up to my thread about band saw mill pad. #3
It totally depends on exactly what BSM you have, for "mine", 10 - 12" to the top of the track is just about right.
SR
   / A follow up to my thread about band saw mill pad. #4
Here are pics of my old property and my current property.
I have been using my HF mill on the ground with no problems.
I got some logs a couple weeks ago (on the trailer) I had to load them with the engine hoist and com-along!
SR
SR. Thank you for responding. I strongly considering the Woodland Mills model HM 130.
I believe it comes with leveling "legs" under the rails.
GGK
   / A follow up to my thread about band saw mill pad. #6
I have seen where some people will put the track on a bit of a downward slant so they are pushing down hill. I am pretty level where I am at, I will re level once spring comes around. Forestry forum has a lot of info too.
My plan,come Spring, is to pour eight piers in two rows . They will be positioned 26" apart and 7' between each pier.
I have fabricated eight rebar cages that will fit inside of my homemade reusable concrete form. A 3/4" threaded rod is incorporated into each rebar cage to secure a 6"x 6" beam. The form measures 14" x12" x62".
I have a couple of photos but since Photobucket has their policy change I still haven't found a similar program.
GGK
Flickr
   / A follow up to my thread about band saw mill pad. #9
Sounds like you have a solid plan. With all that rebar, nothing is going to go anywhere!!!!
   / A follow up to my thread about band saw mill pad. #10
I like the idea of having a 4' wide, 4' deep, 8' beyond building length long dug out pit under the sawmill floor, for some sort of sawdust removal, like maybe conveyor belt, or maybe a long sawdust box that can be dragged out when full. At my mill if I had removable steel grating in the floor for sawdust to fall threw, it would save me a tremendous amount of time pushing sawdust out the side hatch into a sawdust box.
video 2013 08 03 17 27 39 - YouTube
2018 Ford F-150 Crew Cab Pickup Truck (A55788)
2018 Ford F-150...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
2021 KENWORTH T270 (A55745)
2021 KENWORTH T270...
Black Plastic Mailbox and Post Kit (A54865)
Black Plastic...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
